Question about Sony SLV-N750 VHS/S-VHS playback VCR
Take-up reel in Sony SLV-N750 doesn't take up.
This VCR was making grinding, crunching noises. I took the top off and take up was not happening with tape being spewed into the insides of the VCR.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Better to buy new VCR as its mechanism is hard to repair due to spares.
  • 4,234 Answers
The idler assembly is not engaging the takeup reel correctly. Examine the gearing between the hubs for debris. There are parts available for this deck, but it is difficult to say whether or not you actually need any. Check for the debris first and let me know what you find.
Dan
Posted on Feb 06, 2009
Need new sony vcr remote
Try searching Curry's Partmaster website, if you are in the UK.
Mar 30, 2013 | Sony SLV-N750 VHS/S-VHS playback VCR
Our Sony Video cassette recorder model SLV_N750 won't play??? The tape is going into play, but the reels are not turning. The VCR starts with a snowy picture and guickly stops and won't play?
The problem is the idler assembly or the black square belt that drives it, this will cause the vcr to shutdown preventing tape transport. The vcr will need to be dismantled for repair, I recommend a tv technician to check your machine with an estimate.
Jan 08, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
110 to 220 conversion
a converter plug should be fine
Jun 01, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony VCR ''Eats the Tape'' Model SLV-N750. It plays and records but doesn't release tape. It does not repond after I try to run forward or back and does not advance on ''Play'' but shuts off. Is there any...
If this unit is 4-7 years old then TOSS it. As time goes by the rubber gets soft and the units timing gets whacked. Repair will be more than what it's worth , unless your emotionally attached to it ...
Please rate!
Mar 13, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
CAN'T SET VCR (SONY SLV N750)TO CH 3 OR USE MENU
This is a link to the owners manual for your unit, click --->here<--- to download.
in brief, connect antenna, plug in vcr, turn on. if ch3 is not auto tuned, it can be manually set from the instructions in the owners manual.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 16, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
SLV-N750 compatibility with DTV signal
As long as your cable company converter box is feeding your VCR, you should be ok. The cable box should convert to analog which is what your VCR records.
Jan 19, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Remote control code
That doesn't sound quite like the usual procedure for programming a universal feature on a remote. Should have to put the remote in TV mode, then press something to get it into programming mode, then put in the code for your particular TV.
Oct 17, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Vcr jams on eject
What do you mean 'Tape crunches" Do you mean that there is tape slack, which then crunches when Tape is lifted during Eject? If that is the case, then the Supply Reel Roller Brake is bad. it is a Felt Pad, which needs replacing. If the entire eject operation is wonky, or if it's timing is bad, then I suspect that One of the eject Gears (On either side of the Mechanism) is damaged and needs to be replaced. One question, i assume that you are able to eject the Tape eventually, and so - Does the Tape Load into the VCR properly, when you insert it into the machine? This will help me in giving you a better diagnosis.
Mar 13, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-N750 VHS/S-VHS playback VCR Logo
179 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
