Question about Weslo Cadence CT 4.8 Treadmill
My old weslo treadmill won't run
The power comes on and the control panel comes on, lets me program everything, but when I push start, nothing happens.  When in manual mode, you can usually start walking and it will move.  Now I press extremely hard with my feet to get it to move, too hard to use it.
  • 103 Answers
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Posted on Nov 25, 2009
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
mohtwister
  • 37 Answers
SOURCE: Lost owners manual
try this: http://fitness.owneriq.net/manuals/mfg/weslo/cadence_450_model_no_wltl35520.html
Posted on Jun 02, 2009
SOURCE: given a Weslo Cadence 840 but panel is not providing read out
just got one myself not sure if you have yours question answered already but i will tell you anyway.. on the left hand side of your base read out there is a slide up panel and it takes 3 aa batteries to work the digital readout..
Posted on Aug 17, 2009
SOURCE: lost key for my weslo cadence 860
We found the key.
Thanx
Posted on Sep 03, 2009
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
Weslo g-40 won't come on
see the videos and LUBE the deck belt +rollers bearing .
Feb 04, 2013 | Weslo Cadence G-40 Folding Treadmill Sale
The meter that you set that tells you your speed, distance and calories burned stays at 0:0...the mode moves around when you push that but it stays registered at 0 for all modes. I put new batteries in it...
hi,
check ur tread mill's control consoles press button switches first. if all good the other chance is, ur control console have a programmed ic (integated circuit) in it. some programs are loaded in that ic, with which its displays speed distance traveled and all other settings. may be posibiliy for the ic get faulty. if so, the any way is consult the manufacturer, because you will not get the same in open market.
ok
Dec 27, 2010 | Treadmill Doctor Weslo Cadence Ex16...
I just bought a weslo treadmill it was a floor model buyt i didnt get a key now the readmil wont start
hi, the key isnt a problem to get. ive seen some selling in ebay just type in weslo treadmill parts and some listings should come up. or of you go on the ICON HEALTH & FITNESS LTD website these are the main people who sell weslo treadmills leeds based. or their telephone 08451770512. the replacement key is about £12.00 to £20 hope i have helped.
Nov 13, 2010 | Weslo Cadence CT 4.8 Treadmill
When i plug in my weslo 60se treadmill, the incline motor runs up and down and the screen is blank
plug it back in(power cord) insurt key, let the incline go up,then it will go back down on "her" own-do not touch anything, she's teaching herself/going back to school, or they say"calibrating" when she goes back down, it will stop and you will hear a "beep beep" and then your screen will apear,ready to walk-in future IT will do this from time to time, just let her do her thing... a Sears teadmill tech
Jan 05, 2010 | Weslo Cadence 60 SE Treadmill
Cadence weslo 340 cs treadmill wont engage treadmill
If the transformer does not produce a "hum" the power is either not reaching the rectifiers or the rectifiers have died . Not likely if the machine was running last time prior to being put away. Try physically advancing the tread/belt to set the motor to a different contact starting point since corrosion (ambient humidity) may have dulled the motor contacts(brushes).
Dec 31, 2009 | Cadence Exercise & Fitness
My weslo 860 was in use, it then just stopped but the screen was still reading. it also had a burning scent coming from the motor area
Sounds like motor controller just burned out. If elevation and other function starts normally but belt doesn't move that your problem.
Nov 15, 2009 | Weslo Cadence 60 SE Treadmill
Weslo Cadence CT 4.8 Treadmill Logo
1,032 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
