Question about Canon PIXMA® mini260 InkJet Photo Printer
Don't have manual and can't change cartridge
I need a dummy manual. I can't even seee where to put in a new cartridge.
Nancy
  • 382 Answers
Here is the cannon site for helping you. Good luck and hope this helps. HAve a good day.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=BoxContentsTabAct&fcategoryid=118&modelid=14098#SupportDetailAct
Posted on Feb 05, 2009
  • 1,602 Answers
GO ON LINE AND TYPE IN
CANON PIXMA MINI260 INKJET PHOTO PRINTER MANUAL
ENTER
OR CANAN MINI INKJET PHOTO PRINTER MANUAL
ENTER
ROD
    President:
  • 2,110 Answers
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I m unable to download the proper printer driver for windows xp 32 bit i don't know even how to use this printer where to put paper, & how to change cartridge, what model of cartridge etc
Please check the content of your printer. You should have there the manual , cables, and CD driver. If you don't have, please get down loaded your printer driver at manufacturer website. Check the model and type then search download bar.
May 06, 2011 | Office Equipment & Supplies
Inserted new toner it says CRU FUSE ERROR
If you have a CRU Fuse error, you have probably purchased an after market toner cartridge. If so, take the cartridge out of the machine and at the back of the cartridge you will see a small 'dummy' fuse. Take that 'dummy' fuse out of the cartridge and your printer will work. I know, it happened to me.
Nov 16, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Canon MP140 fails to print
I don't think that has anything to do with reaching the board of 5000 copies. Your cartridges have no chips on them or anything. You might actually have a problem with your black ink cartridge, as the printer is telling you. Remove the black cartridge, gently wipe the contacts with a dry cloth and put it back in. Hold the "resume" button (triangle in circle) for about 10 seconds to try and reset your cartridge. If none of that works, I suggest you buy a new black ink cartridge.
Apr 07, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Unable to print document
Please tell me you are using factory new Canon cartridges.
Third party or even worse, refilled cartridges are the preemminent cause of ink failures.
Don
Feb 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My Brother MFC 420CN all in one printer won't pring colors even though I've put in new cartridges and cleaned the heads. Brother website says if it is cleaned several times and still doesn't work it will...
Are you certain you removed the celophane from the new cartridge?
If this doesn't fix it - remove the driver and reinstall - get the newest driver for your printer that will work with your operating system.
If this doesnt work ... well it is worth $50.00 towards the purchase of a new printer at Staples and Office Depot. You probably cannot get it fixed for less than the price of a new printer.
Feb 13, 2010 | Office Equipment & Supplies
I put in a new color cartridge and my printer, not compatible..
Consider this: Using name brand cartridges is more expensive... but works. If you're using the name brand replacements... good. If you've chosen to use refilled ink, some of the features do not work as well as the original replacements. I used refilled cartridges in my Lexmark All-In-One and the "Ink needs refill" applet did not work correctly... so I turned it off...
Oct 25, 2009 | Office Equipment & Supplies
Won't print from 3ebk cartridge
i think there is problum in ur cartridge cas adoptor , clean cartridge circuit plate and put cartridge then try
Jun 05, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Canon PIXMA® mini260 InkJet Photo Printer Logo
112 people viewed this question
old marine
old marine
