Question about Asko D1876 Dishwasher
The upper and lower blades will not spin; not cleaning dishes
The upper and lower blades will not spin; dishes are not being cleaned.. I can hear the motor, after the machine has started, but I do not hear the sound of the upper and lower blades spinning. If I then open the door, the bladdes have not moved.
  • nedh Apr 12, 2009
    the spray arms on my 1876 are not moving as well. Water is coming out of a 4 inch or so round plastic circle on the right wall. Does this still sound like both of the arms are clogged up! Would be very strange for both arms to be clogged. I am not getting any error messages.
    Habit-Forming:
    New Friend:
  • 107 Answers
Hey there, i want to suggest you something special
Hydration Water Bladder with DURABLE and QUALITY Material.
100% Leak Proof Design to make any sportsman Happy
BIG OPENING - EASY TO CLEAN
https://www.amazon.com/SELLER-Hydration-Water-Bladder-Backpacks/dp/B01E4MP8Q0
Posted on Jul 15, 2016
    Scholar:
  • 93 Answers
You will more than likely find that the holes in the arms are clogged with food you will need to remove these and unblock all the holes on both arms and replace them the arms usually come of by unclipping or on some machines there is a nut at the base centre of the arm wich you will need to unscrew first then pull them off.after you have unblocked and cleaned the arms then replace and it should work.All this above is assuming the machine is takeing on water to check this start the machine give it about 3 or 4 minutes and check if water is in the machine if there is then do the above if no water then let me know and we can investigate further.
Posted on Feb 06, 2009
  • aferraro Nov 01, 2010
    Thanks for your suggestions which I have tried but still no success I'm afraid. There is water coming in, and for a little experiment I also increased the amount of water coming in with no change. The arms are not spinning at all, and all the water jets are clear. I did the trouble shooting program in the user guide, and I do near a noise when the circulation pump is tested but don't know if the noise is normal. There is no noise whatsoever when the fan motor is tested though.
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the...
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
Dec 30, 2010 | Asko 24 in. D3350 Dishwasher
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Whirlpool Dishwasher Model GU1200XT
Check the upper spray arm for debris plugging the spray holes, if clean then pull off lower spray arm and filter screen, and clean and remove any debris found in the sump, check the disposal blades as well. You will need a torx style screwdriver to remove the sump screen on this unit. You can buy a set for under $10 at your local hardware store.
Feb 22, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Will not clean
I had the same problem with my Kitchenaid dishwasher. It would fill with water, heat up, and sound like the motor was running just fine. However, the bottom dishes would be poorly cleaned and the upper dishes would not be touched. Fortunately, my repair did not require pulling the dishwasher out from under the counter. The repair was done within the wash cavity.
I completely drained the water out of the dishwasher (if it hasn't ran through it's cycle). Use a turkey baster if necessary. I Removed the lower wash arm, upper arm supply tube and then started removing plastic cover parts until I worked my way down to a part called the "Chopper assembly". Torex screwdriver bits were necessary in my case.
The chopper assembly is a small metal screen, a metal blade and a plastic drive rod that spins the metal blade.
c9a1a9f.jpg Chopper assembly
In my case, the plastic part of the assembly was broken and the chopper was not spinning. The screen was plugged with food junk and water could not get past the screen to the wash arms. the spinning blade also ads a little pressure...when it spins.
the part is $21 online, but may run $30 at a local parts store.
Dec 27, 2008 | Maytag Dishwashers
Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Mar 25, 2008 | Dishwashers
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Open Questions:
See all Asko D1876 Dishwasher Questions
Asko D1876 Dishwasher Logo
249 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
