Question about Microsoft Xbox 360 Console
My trey will not open
There iz a little black band that came off and now the trey will now even move when i push the button :/
WHAT DO YOU MEAN WHAT DOES IT DO EXACTLY/
Posted on Feb 05, 2009
CD hung behind trey. Trey in out position
you will have to open the cd tray up to get it out.
Feb 06, 2014 | Dell Inspiron Computers & Internet
Tip
How to eject your CD/DVD rom Sometimes a CD or DVD is put into the trey...
Sometimes a CD or DVD is put into the trey incorrectly, hence the trey will not open.
Here is how we fix this problem.
Take a sall pin, like a paper clip, push it into the small hole near the eject button.
While doing this, gently pull out the trey with the stuck cd.
You should be able to use your drive again.
Kind regards
Andrea
on Feb 17, 2010 | Computers & Internet
Senco nailgun sn4 plunger doesn't retract
The driver will not retract if the driver is bent, piston oring too loose or too tight or the check band is loose or missing. Easy test, remove air and push the piston to top of cylinder. It should move up with very little effort. If hard to push, oring too tight or driver bent. If piston moves too easily and drops back down under its own weigth, oring too loose. If easy to push and stays suspect check band (check band is located on the outer lower part of the cylinder. Looks like black rubber band or series of orings that fit over series of holes. ). If the band is split or broken, replace with series of orings to cover all holes, or use any rubber like bicycle tube. Good luck with your repair.
Sep 28, 2012 | Air Tools & Compressors
On the sony crx140e....I push the button, tray opens...push button to close, and tray moves about one inch and just stays there...push button again , tray opens again....So, gets stuck or won't close ...
It's age. It's an older drive. You can tell by the 8x4x32 speed.
Sony has manuals at http://sony.storagesupport.com/product/180#documents
My advice is buy a new one. Make sure you specify anEIDE interface and not SATA. They can be found online for as little as $18. Walmart has them too, but run almost double in cost.
Aug 26, 2010 | Sony Computers & Internet
The tray does not open
Hello
Do you know if there might be a cd stuck in the trey, if so, here is hoe you fix this.
Take a pin and push it into the small hole near the eject button. Push it in until you feel a resistance to movement of the pin, while doing this, gently pull out the try.
If there is no cd stuck in the player, the problem is the little rubber band which drives out the trey. If this is the problem, you should hear a noise if you press the eject button. It is really cheap to fix. Hope this can help you.
Best regards
Andrea
Nov 03, 2009 | Philips MX6050D System
The door will not open on my dv-5700a dvd rom drive.
Hallo
The reason for the trey not ejecting may be because there is a disc stuck in it from previous use. Now you need to force pen the trey. The way for doing this follows:
There should be a small hole in near the eject button.
Take a pin or small paper clip and push it into the hole.
When you feel a slight resistance, gently pull out the trey.
This will not damage the device, the small hole is made for this sole purpose. Really hope this can help.
Best regards
Oct 14, 2009 | NEC DV-5700A Internal DVD Drive
CD CHANGER DOSE NOT OPEN AND AN ERROR CODE APEARS
If an error occurs ond the trey does not eject, the problem is most probably that the cd is crammed in the wrong way. So now you need to force eject the trey. This will not do any damage to your device, so even if this is not the problem, you should be able to get out the cd that is stuck.
There is a little hole near the eject button, you need to push a pin into the hole untill you feel there is a resstance. Then gently pull out the trey while holding the pin in the hole.
This should work perfectly. Please rate this.
Best regards
Sep 29, 2009 | Sharp Multi-System Mini Component System...
Drive bay won't open Power lights flas.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
Sep 25, 2009 | Microsoft Xbox 360 Console
The repair shop suggests sending my cd player to the manufacturer. How do I find out where and if possible? Can't get loading tray to open - seems jammed. Model C-707CHX
Hey there
Usually there is a lttle hole in the front panel near the eject button. All you need to is insert a pin into the hole and just pull open the trey.
The button in the little hole releases the locking mechanism so the trey can move out freely.
Please rate solution
Best regards
Sep 15, 2009 | Onkyo Audio Players & Recorders
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
