Static interference on LCD monitor
My problem of my monitor is the static interference runing up and down will you please give a solution with this thank you. I have an acer 19 inch monitor. Everything is "squigly".
  • 1,602 Answers
BUY A CHOKE AT THE COMPUTER STORE AND PUT ONE ON EACH END OF THE MONITOR CONEECTION AND ONE ON THE INPUT ON THE MONITOR THAT PLUGS IN COMPUTER SYSTEM, IF THERE IS ONE THAN YOU WILL HAVE TO GROUND THE MONITOR,
CHECK THE POWER OUTLET TO SEE IF IT PROPERLY GROUNDED, SOME ONE MAY OF ADDED HOT WIRE TO THE GROUNDING POLLS.
THIS DEVICE PLUGS INTO THE HALL OUTLET AND LETS YOU KNOW IF IT IS PROPERLY GROUNDED OR NOT GROUNDED.
THAT CAN VOID A WARRENTY ALL TOGETHER
ROD
Posted on Feb 05, 2009
My monitor has a pinkish tint to it. I've tried adjusting the settings and turning down the red but it is still pink. Any suggestions?
Anything magnetic close to the monitor can cause this happen. Make sure there is no magnetic interference.
Jul 21, 2009 | AOC LM742 17" LCD Monitor
Static interference problem
The Graco digital iMonitor scrambles the signal as it travels between the monitor and the receiver, making signals nearly impossible to be heard by others.
I had good experience with this product, it didn't suffer from the static noise problem.
Jul 16, 2009 | Graco Imonitor Digital Baby Monitor
I have have 2wire home portal 1800HG and it has low signal strenth. the techs at SBC have tried to strengthen the signal but it still gives it low strength and if I leave the room it's in I can't get any...
Sounds to me that ur getting what we call an EMI or electro-magnetic interference. These are signals that interferes with ur wireless signal that comes from other objects like ur computer monitor, TV, microwave, and even the statics on the carpet.
Try relocating ur 2wire to another place. Do NOT put ur 2wire in a carpeted floor or on top of the computer monitor or tower. It would be best to place it on top a wooden surface.
Keep me posted about this.
Jan 01, 2009 | 2wire HomePortal 1800HG Router...
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
22" Acer flat screen monitor
this sounds like an electrical fault or failing component, within the Monitor.
Check the cabling, to ensure it,s not damaged-broken-kinked et,c. by carefully moving the cable gently side to side and up and down.
If it puts itself right for a second or two. you can assume its a broken internal wire, within the lead.
Or a dry soldered joint-Connection.
Mike @ compurepair.
Sep 16, 2008 | Acer AL2216WBD LCD Monitor
E machines e15T 15" lcd
The discoloration problem is due to the near by magnetic field (magnetic interference or due to magnets) appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss.
Jul 04, 2008 | E-Machines e15t 15" Flat Panel LCD Monitor
Speaker interference
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jun 23, 2008 | Microsoft LifeCam NX-6000 Webcam
Acer Aspire 9303WSMi - 17" LCD Screen is showing coloured static..
More like the LCD Inverter Board..a loose connection would not cause that, unless you pulled the video cable by openening and closing the lid, but again that too is highly unlikely..
Jun 03, 2008 | Acer Aspire 9300 Notebook
Flatscreen monitor with built in speakers
have a tech check your tv must be getting some voltage spike.good luck
Apr 15, 2007 | Samsung SyncMaster 151MP 15 in. LCD...
Interference on screen
Are you able to test this monitor on another computer as it sounds like a graphics card fault and not the monitor.
Dec 01, 2006 | Dell E171FP 17" Flat Panel LCD Monitor
Computers & Internet Logo
626 people viewed this question
David Payne
David Payne
