Question about D-Link AirPlus DI-524 Wireless Router
How do I reste my password?
I'm trying to connect a laptop to my wireless connection. Every time I try, I get a warning that says that the router did not respond. I'm not sure if my password is correct or not. I tried to create another wireless network but I can't seem to connect to the router/wireless network even from my host computer. What am I doing wrong?
  • 1,527 Answers
Hello have you turn the power off and press the reset button on the back of the router press it for 30 seconds good luck
Posted on Feb 05, 2009
Problems with Acer laptop running XP, can only get wirless access if there is no wireless password
Chances are that it is still remembering an old password somewhere in the properties... dig through the options an properties to see if there is a place to enter a password that may be overriding the one you are entering when you try to connect.
I know it sounds wrong, but I've run into this before on Windows 7 laptops and have found a previous password embedded in the properties that (once the correct password is entered there) solves the problem.
Nov 01, 2017 | D-Link Wireless N 150 Home Router
I am connecting the netgear ptv adapter to new toshiba laptop. It will connect but loses connection after a few minutes. Light goes out on the unit.
try to do this rest password on the router is u have to put in 0 26 times to reset the password typical problem of that kind of router try that and let me know leave a rating thanks.-natefixit
Apr 13, 2011 | NetGear Push2TV TV Adapter for Intel...
Can't get hp photosmart wireless to connect to router
Sometimes it is difficult to connect a printer to a wifi network.... First, ensure that your printer has wireless capability and that it is in range of the router... (This can be fixed by moving closer to the router)..... If this is true, then you can move on to step 2... Step 2, go to "Settings" and find Network Settings or anything in there that has something to do with wireless..... Step 3, Once you have found that, select it and it should have some kind of Wizard to find all in range wireless networks.... Step 4, Select the wireless network that you wish to connect, (make sure at this time to have the password for your network at hand).... Step 5, Enter your password, enter the correct settings, and connect.... Allow some time for it to connect about 5 minutes..... After, this you should enjoy wireless printing from your laptop(s).... Hope this works :)
PS: If you are attempting to print with a desktop, then skip all those steps..... Just Easily connect the USB Cable from your printer to your desktop..... Your computer should do all the rest :D ALSO, if this doesn't work for you laptop(s) then a quick fix is to use the USB cable that came with the printer and connect it from your printer to your laptop, again your computer should do all the rest :)
Jan 08, 2011 | Computers & Internet
My N1 vison keep losing on wireless connection when i used 2-3 wireless devices in same time. My connection is wired to my Desktop PC & wirelessly to 1 laptop, 1 iPhone and newly 1 iPad. I noticed that...
If you have a 3G phone in the house, It operates at the same frequency and is a nono.
If not I would suggest you completley rest modem and re-enter U/N, P/W etc and set up secure network also. If still a problem, maybe faulty modem.
May 10, 2010 | Belkin N1 Vision Router
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
Forgot password to log on for my wireless connection trying to add my Wii and now cant even get my laptop back online
Find your manual for the router or go to the manufacturers website and download a pdf version of it. You can do a hard reset which will loose all the settings but you can then get into it with the default passwords. Unfortunetly most wireless routers seem to die after about a year and they do so gradually.At first they loose connections then they just don;t connect. You may get out for a while using a wired connection but eventually that goes too. You can get a good router for $30 and up so if the rest doesn't fix it the first time you will probably need to replace it.
Mar 23, 2010 | Computers & Internet
Can't access
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Or you will need to update the firmware to rest the router.
Nov 08, 2009 | NetGear RP614 Router
Cannot connect to my D-Link AirPlus Xtreme G DI-624 wirelessly
In case like this one sometimes it is best to reset the password then try to connect each of the devices.
The D Link 6 series router where good but a little tempermental at times. Also you could check the Dlink site for new firmware as from time to time manufacturers make improvements even after the product has been to market.
Sep 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Device password requested on 1 or 4 laptops, 1 laptop can wiifii and no wiifii on the others
u set up ur buffalo airstation on the 1st laptop tat is working fine,,and at tat time u secured ur wireless tat no one can else can connect to it..specially ur neighbours..u have to use tat password on the new computer.and tat will do it
May 09, 2009 | Buffalo Technology Buffalo AirStation...
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
