Sewing Machines Logo
Posted on Feb 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need manual for singer serger model # 14sh654
The serger is a overlocking machine also ultralock with differential feed. These are all the # on the machine 1.OA S.NO SH 60Hz 13AB dont know what they mean may be you do but they were all on the plate with the model #.
  • 1 more comment
  • cabralsonia Mar 28, 2009
    I needmanual for singer ultralock differential feed
  • erdos Apr 04, 2009
    I also need a manual... :)
  • Anonymous Mar 14, 2014
    I have a Craftmaster 110 Differential Feed Serger and am missing the instruction manual, can you help?
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Feb 05, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801221
Points
33142
Hi Wendy. Go to this web address and you can order what you need. http://www.sewingmachineparts.net/index.html
Please remember to rate my answer. thanks.
I have a Singer Ultralock Model 14SH654. The 2nd thread from the right keeps snapping after changing spools.
This is sometime caused by you using a new or different brand of thread that has a weaker tensile strength, (Snaps with less force), or the tension on the spool might need adjusting.
My overlocker is 25 years old, a friend borrowed it with the manual and she lost the manual.Now every time she borrows it I have to try to adjust the tension on the 4 threads as they are all different
Singer has many of their manuals available as a PDF on their support site: https://www.singer.com/support . Entering the model 14, I found the link to the 14U344/14U344B/14U354/14U354B Serger/Overlocker manual. It was the seventh link (on page 1) of 33 search results. The direct link is currently https://www.singer.com/sites/default/files/product_manual/SINGER%2014U344_14U344B_14U354%20and%2014U354B%20Serger_Overlock.pdf .
I hope this helps. The images and directions for setting the tension for different stitches starts on page 20 (page 22 of the PDF). If you can, I'd suggest printing at least the tension information pages. If you'd like to get a printed copy, some online sewing machine part stores have the manual. One source is https://www.sewingpartsonline.com/singer-14u344b-serger-parts.aspx?sort.ss_cat_sort=desc&index=67 . The link to purchase the manual is https://www.sewingpartsonline.com/singer-14u344b-instruction-manual.aspx . Alternatively, you could get the manual printed at any print shop (like Kinkos).
Need part number for a part on singer 14sh654
Singer has a PDF with the illustrated parts list for the 14sh654 available here: http://parts.singerco.com/CPpartCharts/14_CG_J_SH_T/14SH644_14SH654.pdf . There are two different models listed for 14sh654 manuals. However you can download them (or buy them). To download the Ultralock with incandescent lamp manual, go to http://www.singerco.com/uploads/download/434_14sh644_654_e.pdf . For the Finishing Touch (LED lamp), the manual is http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf .
I hope this helps.
1helpful
2answers
I am doing some sashes for a wedding and i want to know on my serger 14SH654 ultralock how to do a rolled hem
A rolled hem on any overlocker is formed by using the right hand needle only, and the two loopers to form a narrow three thread seam. You also need to retract the seam width finger as Trial2962 said. This is a little finger that sits on the stitching plate and the loopers form the stitching over it. By retracting it, the looper threads can form a narrow seam and in fact, roll the fabric inside the seam. You need to move the cutting blade as far right as it will go so you are trimming as wide as possible from the needle, turn the tension on the top looper rigth down to 2 so it is very loose and this thread wraps around to the underside. And tighten the lower looper tension to about 7 so it hardly shows and sits right up against the needle thread. Adjust and test until you get the seam looking like this, then turn the stitch length dial (on the right side by flywheel) down to 0.5 to close the seam right up tight. Lastly, if you can source it in the right colour, buy woolly overlock thread and run this through the upper looper only, this thread is fluffy and when not under tension, relaxes and "fills" out so the seam appears like a continuous coverage over the fabric.
You will need to practice a few runs and go slowly on corners, a curve is obviously much easier to serge than a right hand cover so if you can, cut the fabric with curved ends, much easier to get a great finish. When you chain off at the end, you need to unravel the tail threads and pull them inside the seam for a few mm with a needle to get a smooth finish, then trim the tail and seal with a drop of Fray Stop.9_26_2011_11_26_51_pm.jpg
1helpful
HOLA! HE INTENTADO ENHEBRAR MI ULTRALOCK DIFFERENTIAL FEED Y NO LO HE LOGRADO. POR FAVOR, DIME QUE PUEDO HACER. GRACIAS.
Tienes la manual?
Lo puedes descargar en el sitio web de Singer.
http://www.singerco.com/accessories/manuals.html
Pone 14SH645 y hacer clic en search.
En el siguiente pagina aparece varios opciones, elige el ultimo y hacer clic en free download!
Espero que este ti ayuda.
2helpful
2answers
4helpful
2answers
6helpful
2answers
I am looking for an instruction manual for a singer serger ultralock model 14u46.
Dear customer,
  You can download the instruction manual from the following link..
its the company's website and very much trustworthy..
plz rate this solution.. thank you..
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
