Question about Dell Latitude C610 Notebook
The fans won't turn off !?
Ok well basically my screen stopped working last night, so i opened it up took the screen cable in and out etc... not its all up and running again, except the fans are constantly on full power aa soon as i turn it on. They wont be normal and turn on when needed. Cold you help me return them to their previous state. So that they only come on when needed etc...
Cheers
Scott!
  • Scott Burns Feb 05, 2009
    Yeah i know but they never run fully like proper full blast, they always run slow. As i have my laptop on a fanpad thing. But since i made a little tweak inside. Its effected the fans.
  • 1,602 Answers
THE FAN RUNS ALL THE TIME, THE CPU CAN COOK AN EGG ON IT IN A MATTER OF SECONDS.
GO ON LINE TO EBAY, OR A VENDER OF THAT PRODUCT, RECONDITION ELECTO-MECHINICAIL USED COMPUTER EQUIPMENT STORE.
ROD
Posted on Feb 05, 2009
  • ROD GANDY Feb 06, 2009
    THE FAN INCREASE WHEN THE CPU ARE DOING COMPLEX CALCULATIONS, THE FAN SHOULD RUN ALL THE TIME FROM THE TIME YOU TURN ON AND UNTIL YOU TURN IF OFF ALSO MAY CONTINUE RUNNING AFTER YOU TURN OFF THE COMPUTER SO IT CAN COOL THE COMPUTER SYSTEM CURCIUTS AND OTHER IMPORTANT PART OF THE COMPUTERS LAYOUT AND DESIGN.
    ROD
2 Suggested Answers
LaptopExpert
  • 458 Answers
SOURCE: Dell c610 fans stay on and won't turn off!
Go Here-------> http://www.diefer.de/i8kfan/index.html
and download the 18kGUI fan utility software, it runs great on dells, you can control your fans, or set it to auto, or low etc....
Posted on Feb 06, 2009
My goodman condensing units fan won't start to turn on its own
Hello, usually this is a sign of a bad capacitor. Replace the capacitor.
May 21, 2012 | Heating & Cooling
2004 Chevy Trailblazer hesitating
Low power lean conditions cracked air intake tube GM Testing by a qualified repair person with proper diagnostic tools is the way to a proper fix , not someone guessing !
Mar 19, 2017 | 2004 Chevrolet TrailBlazer
2002 Ford F 150 Supercrew,,,,5.4. noticed cruise control stopped working.........next day,,turned on a/c ,,fan motor works,,,no cold air,,,,,,,,,,,,tried turning on heat,,,,,,fan works, no HOT air....
try disconnecting the cluster fuse and the radio fuse and see what happen if everything work...u might have an open circuit or a short on one of the electronic in your truck
Apr 21, 2010 | 2002 Ford F150 Regular Cab
Base station won't connect to isp
Change your internal network from 192.168.1.x to 10.0.1.x...many times you find smaller ISP's that use the default address scheme and cause conflicts with the default address used on most routers, etc.
Jul 17, 2009 | Apple AirPort Extreme Base Station
Feb 05, 2009 | Dell Latitude D600 Notebook
NO VIDEO
PS3 is The amazing device by sony but it has some common problems like sound problem, video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identicle. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
Jul 12, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Dell Latitude C610 Notebook Logo
106 people viewed this question
Alun Cox
