Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
CRAFTSMAN I have a Craftsman 1/2 HP opener (no safety photo cells). I just replaced the worn out gear, and put everything back together again precisely. Now when I try to operate the unit, it runs find but one for one second. then it stops, and goes into reverse for one second. It does this with the chain attached, or without the chain attached. No adjusting of any kind changes it. It just runs one second one way, stops, and runs one second the other way. I have busted my brain trying to figure out the problem and have double/tripple checked everything. Someone please help.
  • 19,396 Answers
The Craftsman HP openers will go automatically to reverse if it does match too much resistance.
If the opener goes to reverse it is because it had been not properly assembled ad geard are not running, the opener stops and start reverse for a couple of seconds.
The opener should be taken apart and re-assembled.
Posted on Feb 18, 2009
    Sergeant:
  • 326 Answers
Check out whether you have fitted the gears properly.it will be upside down.just make it proper and check out again.
Posted on Feb 05, 2009
    Brigadier General:
  • 5,158 Answers
Sounds like the safety switch needs adjustment... it thinks it's hitting something so it stops
Robert
    President:
  • 2,110 Answers
You may have put the chain back on out of "sync" with in internal up and down stops. You may have to take the chain off the motor sprocket and run the motor to make sure it is stopped in the down position ( watch the rotation of the sprocket to determine up or down position) When the motor is stopped in the down position put the chain back on with the chain Carriage in the down position. Then you can fine tune the up and down stop positions with the adjustment screws on the side.
1/2 hp craftsman door opener moves about 12 inches then reverses back & thats all it will do. just replaced the main two plastic drive gears whenthis started
First try adjusting the force limits. They are up on the motor head. If this works do a 2x4 safety reversal test afterward. It also may be the rpm sensor. Sometimes this can go out with the gears. There is an led light on the motor head. If it is flashing 5 times in a row then it is this for sure. You can get replacement parts at searspartsdirect.com. Thanks BB
Sep 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Engine on 17.5 hp craftsman mower starts but stalls when clutch is let out !
Check all 3 of your safety switches mounted on the mower. Take a wire or connector and connect the WHITE wires together on each switch together one at a time to see which one has gone bad. Once you find out which one is bad, take the 2 white wires and connect them together where they're always connected or replace the switch.
May 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 1/2 hp chain drive starts to close approx 12" then returns to open. replaced main gears 2 weeks ago everything was working. now its about 6" from full open and will only travel 12" then returns...
Make sure you put the black cup back onthe end of the motor shaft and that it is pressed all the way on.Make sure the RPM sensor is plugged in. If neither of these are theissue, then you probably did not have the motor shaft pushed all theway back when you tightened the coupler after replacing the wormgear. Loosen that coupler up and from the front of the motor(opposite end in which the coupler is on) push the shaft back as faras it will go. Hold it there while you tighten the coupler back upand then try it.
Mar 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 4 cylce weed whip engine runs, but head does not engage
The clutch may be worn out and need replacing. The driveshaft may be broken. The gears in the trimmer head may need replacing. Or the drive shaft is not fully seated in the trimmer engine when put back together.
Look at some of these suggestions.
Good Day.
Oct 09, 2009 | Craftsman Garden
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
CRAFTSMAN GARAGE DOOR OPENER PROBLEM
i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opener will not opern
2 flashes indicate safety eye issue. Check you wiring and make sure it is wired correctly and check to make sure the eyes are properly aligned.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
GDO repair
If unit is pre 1993 (Safety beam era), Sears will not sell you any parts. Google Liftmaster gear kit. Buy for $25-30. Not hard if you are handy. Buy the complete kit with bearings.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
23 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
