Question about Dell Latitude CPX Notebook
Processor id recognized as 498mhz instead of previous 648Mhz
I own a Dell Latitude CPx J650GT laptop that I deleted cookies from using microsoft updates. I defragmented. I compressed all files using microsoft updates downloaded to make more room on the puny 13Gb hard drive and now the processor ID shows that it is a 500Mhz not 650Mhz. Is there driver or software deletion that caused this. No hardware failure has occurred and the above operations are all there is that is new that have occurred. I have seen this PIII shown as a 500Mhz/650Mhz processor in certain data and need to understand how it is both. Due to mine now being set at the 500Mhz and no longer the always previous 650Mhz. Please Help !!!!!!!!!!!!!
Signed Perplexed old school techy ! Thanks
  • 1 more comment
  • aercoacher Feb 05, 2009
    My computer right click on properties shows a 498Mhz processor now and it showed a 648Mhz processor always before doing microsoft updates. This was a corporation IT serviced laptop since new before I recieved it and they may have loaded or adjusted settings to allow it to be a 650Mhz not 500Mhz capable system. Nothing bad happened but I would assume that now since it shows that is is 23% slower for the processor isnt it going to operate 23% slower. I dont understand what got changed and need to change it back so it shows 650Mhz
  • aercoacher Feb 06, 2009
    Does anyone know how a processor in a Pentium III laptop which shows in some data I've seen can be a 500Mhz/650Mhz in the same unit. I have seen some other data that shows 700Mhz/1.13Ghz for the same processor as well. Is there a set up procedure that allows one to select either or in this scenario. There must be due to mine changed from 648Mhz to 498Mhz after file alterations. Does anyone know how to set this or apply it ?
  • ROD GANDY May 11, 2010
    AND WHAT HAPPEN??????????????????????????
The processor is adjustable to save power , press F2 when booting & change the speed there.
Posted on Feb 21, 2009
  • 1,602 Answers
THE CPU IS TEST IN BATCHS OF 1000'S THEY WILL MAYBE PICK ONE OUT OF THE THOUSAND AND TEST LOOK A THE MAXIMUIM THE CPU FUNCATION AT THAN PICK A SAFE ALTERNATE SETTING OF MHZ FOR ALL CPU IN THAT GROUP, THAT ONE CPU MAY BE ONLY DEFAULTY CPU TO RUN AT 500 MHZ, THAT ONE HAS A PROBLEM IN THE CURCUITRY OF THE CPU, I WOULD RETURN IT TO WHERE YOU PURCHASED THE CPU AND EXPLAIN THE PROBLEM, INTEL ALSO IN THE CPU SPECIFACATION GIVE A TOLERANCE OF MAYBE 8-10%
ERROR ON ISSUES WITH THE OPERATION SPEED OF THE CPU, LETS SAY THE CPU IS RARED AT 500MHZ AT 1 % OPERATION SPEED IS WILL FAILURE OF 5MHZ, THAT CHIP IS STILL OKAY AND YOU JUST GOT THE RUNT OF THE LITTER.
NOW LETS SAY ITS RATE FOR 550 TO 600 MHZ THAN YOU HAVE A GOOD CASE ON RETURN BECAUSE THE FAULURE RATE IS TO HIGH ON THE % OF FAULTY REQIUREMENT,
I HOPE YOU UNDERSTAND BASICLY HOW IT WORKS OR ASK SOME ONE AT INTEL TO EXPLAIN HOW THE FAILURE RARE ON CPU WORK.
CANDYMANGANDY
PS
THAT PRODUCT IS NOT WORKING RIGHT, HAVE THEM RUN THE TECHNICAIN TEST PROGRAM, OR CPU TEST RATE IS, OR DRIVE PRO, OR CHECKIT SOFTWARE, OR WICHECKIT, OR DIAGNOSTIC UTILITIES SOFTWARE, QAPLUSWIN, OR THE TROUBLESHOOTER PROGRAM ON THE MACHINE.
ROD GANDY THE CANDYMANGANDY
Posted on Feb 06, 2009
Can you change the os on a Latitude CPx from Windows 95 to Windows XP or higher without changing the memory?
You could depending on what is installed. Microsoft recommends atleast 128mb of ram to run XP.
check this page from Microsoft for more info on XP requirements.
http://technet.microsoft.com/en-us/library/bb457057.aspx
Dec 10, 2010 | Dell Latitude CPX Notebook
My dell latitude cpx j650gt does not have recovery partition working and I neeed to restore it to factory settings. I do not have original OS discs as I bought it used.
You do know only certain models have an os image on their harddrive and it is this that is enabled with F9 whilst booting (or other key)Failing this you will just have to install from external Dvd/Cd rom etc-this is the fact.
Davey Snake!
Oct 30, 2010 | Dell Latitude CPX Notebook
I just inherited a Dell Latitude Laptop that
Yes ... Go to Start - Control Panel - System - Device Manager to see if there are any hardware conflicts or any other issues.
Jun 24, 2009 | Dell Latitude CPX Notebook
Windows NT and WiFi????
You can put xp on with no problems - i'm writing this on a cpx with just 128mb RAM and XP. But when you try to use any anti virus you may find it runs very slowly. I'd recommend getting xp and maybe trying a processor friendly anti virus like AVG if you're planning to go online a lot. Hope this helps.
Apr 18, 2009 | Dell Latitude CPX Notebook
Need 2 install the fastest PIII processor possible on CpxJ650GT
you obviously seem to have the adequate knolledge so why dont you overclock it...
overclocking used to be a touchy subject but know its undrstood that that it creates no problems..the chips are designed to be overclocked,in fact overclocked should now not be the trerminology for it ...it was called overclocking cos then it wasnt natural and created unstable systems ..now it is merely enhancing .
Jan 24, 2009 | Computers & Internet
Dell Latitude CPX PC Notebook driver for keyboard
Go to www.support.dell.com and download the drivers there, you can select the model or enter the TAG number which is on the bootm of the laptop labeles as Service Tag
Jan 19, 2009 | Dell Latitude CPX Notebook
External Toshiba 400GB HDD not recognized on my Dell CPx J650GT
New hard drives need to be formatted! So go into the control panel switch to classic view, ( if you are still using category view for the control panel ) open administrative tools, then open computer management. Next open disk management. In disk management your new drive will show as raw, you will be give the option of formatting the drive, select primary partition and format in NTFS.
This will then format the drive, when this has finished your new drive will appear in my computer.
Alan
Jan 18, 2009 | Dell Latitude CPX Notebook
Laptop won't display more than 16 colors
Go to the DELL WEB site www.dell.com
Make sure you download the correct operating system drivers for your model laptop.
To search for the correct drivers by use the Service Tag number, this is printed on a label on the bottom of the laptop, it is also displayed in the BIOS.
Dec 31, 2008 | Dell Latitude CPX Notebook
Dell Latitude CPx H500GT fails when using 2x256 Mb memory in bay
If the laptop is in warranty, then dell will take care of it. Also, are the two ram sticks the same speed? mixing ram can be bad. also, goldmemory software is excellent for ram testing.
lastly, if there is a bios version that allows you to use both ram slots, use that bios. a newer bios is not always better.
Dec 24, 2008 | Computers & Internet
How do you take the hard drive out of a dell latitude cpx J650GT
on the bottom of the laptop there should be four screws un screw those and take the cover off next take the keyboard and top covering off then carfully remove the hard drive which should be loacted near one of the fans.
Nov 26, 2008 | Dell Latitude CPX-J Notebook
Dell Latitude CPX Notebook Logo
328 people viewed this question
Alun Cox
