Back to:
Tags:
Aironet Cisco PC4500 Wireless Adapter
Linux and Xircom CBE1100 Wireless card
By Rogers - usenet poster
I think I've got most of this to work. I've got two laptops one with a
Orinoco card and a thinkpad with a xircom card in it. I loaded the
PCMCIA drivers using the airo_cs definitions. There is a readme from
xircom about this. I'm able to ping the other machine but when I try
to go out the web, the DNS entries do not cascade to the machine. Any
ideas on what the problem is? I've got the machine to get everything
dynamically. Please help.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
pandamama
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
So, from what you said, it sounds like machine A has a connection to
the internet, and you have wireless networking working between machine
A and machine B, and you want to access the internet from machine B.
So you want machine A to work as a wireless router. This capability
does not just happen automatically; you have to configure system A to
do this. Probably you should read some Linux network administration
documents because I don't actually know how to set that up.
-- Dave
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Linux and Xircom CBE1100 Wireless card:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Beresford
Rating: 0%, 0 votes
I may be wrong, but I don't think that is the Xircom CBE card
named in the title of your posting.
You will see that the document you cite
mentions Xircom CBE's in conjunction with other drivers.
In any case, I would give greater weight to
when discussing Wireless cards.
However, your cards seem to be working with this driver,
so I assume your problem is with routing or firewall.
Most distributions install some sort of firewall, I think.
I use the rc.firewall script I found in the IPTables-Tutorial.
As I said, iptables -L should tell you
what sort of firewall (if any) you have.
Timothy Murphy
e-mail:
tel: +353-86-233 6090
s-mail: School of Mathematics, Trinity College, Dublin 2, Ireland
Thank You!
Solution #3
Not Rated (0)
pandamama
Rating: 0%, 0 votes
Hello Tim,
Here is the document that states the compatibility of cards...
Wireless network adapters:
[airo_cs driver] [x86]
Aironet PC4500, PC4800
Cisco 340
Xircom Wireless Ethernet Adapter
I'll try to see if I have a firewall installed. As I recall I don't.
I can connect the computers by wireless. I can FTP and ping the two.
Thank You!
Solution #4
Not Rated (0)
jessie25
Rating: 0%, 0 votes
I'm not sure what document you are referring to.
My /etc/pcmcia/config only binds airo_cs to Aironet cards.
As I recall, you said you had an Orinoco card.
If so, it seems slightly perverse not to use the orinoco_cs driver,
since this is the standard Linux kernel WiFi driver.
However, this doesn't appear to be the cause of your problems.
What exactly is the connection between wireless and the internet?
I'm not clear what your setup is.
Can you connect the two computers by wireless?
If so, do you have a firewall?
What does "iptables -L" say?
Timothy Murphy
e-mail:
Thank You!
Solution #5
Not Rated (0)
Rachel007
Rating: 0%, 0 votes
Well, the readme of supported PCMCIA modules says to use the airo_cs
modules.
I know that the wireless card is working. I can't get the computer to
recognize the DNS entries. When I try to ping an outside website
(#) linux says "Network cannot be reached".
Any thoughts?
Thank You!
Solution #6
Not Rated (0)
Mini Me
Rating: 0%, 0 votes
I haven't understood your question.
How are you connected to "the web"?
If as you say your two laptops can ping each other
then there can't be anything wrong with the wireless communication,
which seems to suggest there is something wrong with your routing.
Can you ssh from one laptop to the other?
I don't know about the Xircom card,
but the kernel WiFi module orinoco_cs works with Orinoco cards,
so I'm not clear why you would use airo_cs, if that is what you are saying.
Timothy Murphy
e-mail:
Thank You!
Can you Help with these Wireless Adapters problems?
Wireless Adapters
dynex network security key
Wireless Adapters
ma machine n'arrive pas ? se connecter sur le wifi de mon...
Wireless Adapters
bonjour j'ai install? windows XP ultimate dans mon PC...
Wireless Adapters
I have recently purchased Motoroker E6 and trying to...
Wireless Adapters
I am using a usb cable to connnect the printer to my pc....
Loading problems.
Repair Service
Find Wireless Adapter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
