Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Wireless connection
Ihve instructions on how to set up my wireless connection, do i set it up on my desktop or lap top ?i have a westell versalinkwellthe instructions but am confused 327w modem that is hooked op to my desktop.i. can fo
    President:
  • 2,110 Answers
You have to setup with the desktop...
Posted on Feb 05, 2009
Westell 6100 connected to a wireless router; wireless internet connection works but ethernet cable connections for desktop and PS3 will not work, even tho the desktop says its connected. This started after...
You have to make sure that in PS3 you select Automatic Configuration under Network Settings.
In Westell 6100, you have to make sure that there is "DHCP" configured on it. You have to access it via web interface and check under IP configuration or so.
Let me know if you want the detailed process for this.
Mar 12, 2011 | Westell Wirespeed ProLine 6100 Router...
Trying to connect wii wireless through my westell 7500 modem from verizon. error code 52230 keeps coming up. on phone with nintendo for an hour. they tried all kinds of stuff that did not work. told me...
It appears that the wii wants to work with wap security not wep. Need to go into the router with the 192.168.200.1 gateway. Next o to the security tab. Set up wap2 security password. On the drop down menu choose tkip and aes (both) setting. On the wii I would clear out the wireless settings and then set up a new wireless connection. Search for said and choose your router. Hit connect and enter your password. Save settings and have the wii connect, should get a connection successful message. Grab some popcorn and enjoy Netflix.
Jan 12, 2011 | Nintendo Wii Console
Can not connect my Lap top to Wireless connection.
Network security key is almost similar to a password.The network administrator set the key.In case you have a personal router logon to 192.168.1.1 on your browser addressbar.Got to Wireless security on the router configuration page.the network key can be edited from there.
May 16, 2010 | Westell Wirespeed VersaLink...
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Message when I try to connect wireless is I need
Check your router configuration under some sort of Wireless Encryption option. Essentially you or someone else set up a "passphrase" on that router which created either 64-bit or 128-bit encrypted keys from that phrase. You'll most likely find this passphrase under the Encryption information.
Mar 05, 2009 | Westell Wirespeed VersaLink...
We have a acer lap topand trying to set it up wireless to our bt hub and it keeps saying on the lap top that there is not interent connection any advice
generally, to set up an initial wireless set up, you have to be connected to the web via a wired connection. this is only to set your setting preferences etc, etc. after that yopu should be able to go wireless
Sep 15, 2008 | Computers & Internet
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
103 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
