Question about Toshiba Satellite L15-S104 Notebook
Removing laptop base
The power adapter plug (female part on back of laptop) has broken loose from my friends laptop and we're having trouble getting to it...we've removed all the screws,batt pack,hard-drive etc and it still seems stuck....is there a trick that anyone knows of ?....what are we missing?
  • olblueduke Feb 05, 2009
    thanks i'll try both....the female part of the power adapter has come completely undone and we're try'n to repair the best we can...as for the warr i think we're ok there..it was a freeby and its past its prime (like most of us)...thanks for the help
  • russbard Mar 11, 2009
    the power adapter on the back of my computer is not working.I thought it was the cord at first but tryied a few and none of them worked.Any suggestions?
  • 1,602 Answers
I NEED A DETAIL ON WHAT HAPPEN TO THE LABTOP AND WHAT DO YOU NEED FROM ME.
THE SCREWS ARE HIDDEN BY TAPE THAT MAY SAY IF DAMAGED IT VOID THE WARRENTY, SCREWS, IN THE BATTERY COMPARTMENT, HARD DRIVE, MEMORY, ANY OTHER COVER THAT HAS SCREWS IN IT, UNDERNIETH THE KEYBOARD, SPEAKER AREA, CPU COOLING FAN HOUSING, CASE MAY SNAP OPEN AND CLOSE, THE LEGS WHERE THERUBBER FEET ARE, REMOVE THE RBBUER FEET AND THERE MAYBE SCREWS IN OR UNDERNIETH THE FEET,
THEY MAY BE SNEEKY SO LOOK IN PLACES YOU WOULD NORMALLY NOT LOOK FOR SCREWS.
THE KEY TOP COVERS MAYBE COVERING UP SMALL SCREWS, NORMAILLY 3-6 SCREWS
IF YOU DIDNT FIND IT
LOOK UNDERNITH THE METAL POWER INFORMATION, SERAIL #, PAPER OR PLASTIC OR LABELS MATERAIL, FILL WITH YOU FINGER FOR A WHOLE OR IND TASION THE SCREW IS UNDERNIETH THE LABEL
ROD
Posted on Feb 05, 2009
  • 170 Answers
Http://www.laptoprepair101.com/laptop/2006/02/04/toshiba-laptop-disassembly-manuals/comment-page-11/
MyLenova T420 not carging
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in themon that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
TroubleshootMag Safe adaptors
http://support.apple.com/kb/ts1713
Nov 27, 2013 | Lenovo 3000 Y410 Laptop
Toshiba c655d-s5133 plugged in not charging
Dead battery? Try another cord/charger with the EXACT same power specs.
Jan 25, 2013 | Toshiba Satellite Computers & Internet
I have acer aspire 5334. AC adapter plugged in but won't charge. Lights not showing on laptop and battery icon not showing its plugged in. Adapter rectangle box led light is on!! Is it charger, battery or...
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Dec 10, 2012 | Computers & Internet
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
Sep 05, 2011 | Acer Aspire 7740G6364 (lxplx02165) PC...
The indicators on the right are flickering from red to green and back again. I checked the power (the adaptor is plugged in) and the energy level is 95 %.
Sometimes this indicates a problem with the battery. Try unplugging the power cord and see how long the battery lasts. If its not very long, then thats the problem. Its noemally something to do with the charging circuit.
Hope this helps.... Dale
May 18, 2011 | Computers & Internet
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Battery does not charge, but remains on with power supply connected. Female to male connection "touchy." Can turn off if cord is barely touched. Main concern being how to fix female part of power supply.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | Computers & Internet
The connection where you plug in the power on my compact presario R3000 laptop is broken. The female part that you plug into is loose and probably broken away from the solder on the mother board it self. I...
Before you pull apart your laptop, check the male connector and power cord of the adapter, check it with a multimeter and or plug it into another Compaq. You could have a broken wire in the power cord, it could save you a lot of work.
To pull apart the laptop, remove the battery, hard drive and CD drive first.
Then remove all the screws from the bottom of the laptop, plus the screws on the back that holds the LCD's hinge to the laptop base.
Take a note of where the screws come from, some may be shorter that others.
The remove the keyboard (the screws should already been removed from the bottom of the laptop).
Carefully remove the plastic cover next to the base of the LCD screen, This may also cover the hinges, if necessary fold the screen flat to enable you to carefully pry this cover up and off.
The plastic top cover is clip fastened to the bottom of the case, carefully prize apart from one side and gradually work around the other sides.
You can now remove the LCD, there are two connects attached to the motherboard, unclip these.
The motherboard is under the keyboard and plastic top cover, there are screws securing it to the plastic base, remove these and you should be able to free it from the base.
Now you can solder/fix the power connector.
I suggest you use a temperature controlled soldering iron.
Don't use too much force, you might crack the plastic parts.
Best of luck and have fun.
Jan 12, 2009 | Computers & Internet
Connection on back of laptop for power broken
Hi, Simply can't get these things..
go to jaycar or any electronics bit retailer and get a female plug suitable for your AC adapter and attach/solder it to the mainboard with a 2 - 3 inch long cable or longer (2 wires). polarity is very important - can't afford to make a mistake.
Leave that female adapter loose & flexible at the back of your notebook, that way you won't break it again.
You are not he only one, Stats = 20% of notebooks die this way.
I am a techy and I see then every day..
I have done many of them, this way..
Hope you can do it too.
Jul 07, 2008 | Computers & Internet
Base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Jun 19, 2007 | Uniden TRU9480 Cordless Phone
Toshiba Satellite L15-S104 Notebook Logo
180 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
