Question about Cuisinart EM-200 Espresso Machine
Can't get milk to foam
My Cuisinart EM100 espresso maker will no longer foam milk; it just heats it. THe steam wand is not blocked - steam comes through just fine.
  • Anonymous Mar 23, 2014
    the foam attachment is clogged. How do I unclog it?
    Problem Solver:
  • 10 Answers
How long have you had the machine? Use a straight pin and poke the opening of the wand. It may be blocked. If the bottom of the wand can be removed, use some pliers, and CAREFULLY remove it, soak it in hot water. Rinse it thoroughly, and replace it back on the machine. If you cannot remove the wand, turn the machine upside down, and check the opening to the wand. It most likely is stopped up. Run vinegar and water through your machine once a week. Calcium build up does the same thing. Good luck! Happy Lattes!
Posted on Feb 05, 2009
Why doesn't the steam work?
Check if you are using it correctly. Select you model from manual
Espresso Makers Product Manuals Cuisinart com
If no hint, TAKE IT BACK WHERE YOU BOUGHT IT; STILL SHOULD BE ON WARRANTY
May 15, 2015 | Cuisinart Coffee Makers & Espresso...
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
The steam wand has broken off, it seems that the plasic holding it in place has gone brittle, can this be replaced
No. It happened to me twice. The first time they replaced the whole machine. The second we decided to buy a different machine.
Nov 04, 2013 | Cuisinart EM100 Stainless Steel Espresso...
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Jura capressa F7 steam milk problem
You should decalcify, when you steam the milk some what gets through to the steam and the build up of these minerals causes the issue
Aug 11, 2009 | Jura Capresso C1000 Espresso & Coffee...
Espresso machine not steaming
If the machine heats up for coffee, then the steam wand tips are probably blocked. Use a paper clip or needle to clear out the holes at the end of the steam wand.
Jul 03, 2009 | Coffee Makers & Espresso Machines
Steamer is not getting hot enough.
Try using the milk clamp on the tube going into the milk.Tightening it will make your milk hotter.
Your steam wand however, is a different problem.
First, check in the programming that the steam temp. is 125 celcius.
If it is, and none of the tubes from the steam wand to the boiler valve are blocked, your boiler temp. sensor may be faulty, in which case, you will need to replace that.
Mar 13, 2009 | Nuova Simonelli Microbar Espresso Machine
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
Lousy foam!
Perform a full descale cycle to clear the steam boiler of any debris or build up. Most likely due to blockage.
Jan 23, 2018 | Saeco Royal Exclusive 30153 Espresso...
Frothe the milk?
he trick to this is making sure you have steam comming out of the wand and not water. To do this, make sure you get the steam started before you begin. To get a light foam that will not deflate, hold the wand just under the surface of the milk. You should hear a steady, high pitched noise and you should not hear the splatter of bubbles popping on the surface. Popping noises mean that the wand is too high in the milk and your froth will not hold up. A low pitched noise from the cup means that the wand is too far down in the milk. This will heat your milk (for hot chocolate), but will not give you a good foam. Good luck!
Dec 27, 2007 | Jura Capresso CapressoBAR 351 Coffee...
Cuisinart EM-200 Espresso Machine Logo
421 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
