Question about HP LaserJet 4350dtn Printer
Faded on left side of prints
HP 4350dt
I'm getting faded prints on the left side of the prints and i have all ready changed the cartage and fuser and transfer roller and reset the maintenance counter and still no luck.
has anyone come across this problem?
thank you,
    Genius:
  • 2,120 Answers
The only thing left is the HIGH VOLTAGE POWER SUPPLY.
Have you removed and cleaned the LASER UNIT?
Posted on Feb 06, 2009
Dell 2145cn Print is faded in middle of page
Check the transfer belt, also get a air spray can, look for the opening to the laser unit inside unit on top side, spray opening to remove dust or toner deposits. Lastly check fuser, it should have a uniform coating on it, if it looks faded in the corresponding area of fades you will have to change. Hope it helps.
Jun 24, 2013 | Dell 2145cn Multifunction Colour Laser...
Hp laserjet only prints clearly on 1/2 the page
YOU PROBLEM IN THE FUSER STAGE MAYBE FUSER FLIM IS PROBLEM
Mar 28, 2013 | HP LaserJet 1200 Printer
Hp laserjet black globs
Your problem is that your Teflon coating on the fuser is very worn.
You need a new fuser, as the failures here are not always visible, because the black spots are formed to get the paper and fading with every turn.
But re-form when it enters another sheet with toner to the fuser and we start the cycle again.
Apr 23, 2012 | HP Color LaserJet 2600n Printer
Print-outs are faded in about the left margin. Have changed cartridge -- no change. Have gone through diagnostics on panel-- no change. Scans, photocopy, fax ... all have same poor fading issue. A...
If the printer is making a crinkly sound when printing then likely the teflon cover on the heating element in the fuser has torn. Assuming that the rest of the fuser components are not damaged a reputable shop should be able to resleeve the fuser for you.
Nov 10, 2010 | HP LaserJet M3035xs MFP All-In-One Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
Printing on my HP 4P Lazerjet produces shading on the left side
Most likely you need to put a transfer roller and a fuser in.
Feb 16, 2009 | HP LaserJet 4p Printer
Infoprint 1532 Faded txt on left half of page and normal on right
The problem is the transfer roller. If you remove the toner cartridge and look at the roller that is under it. It should be seated down. The gears should be on the left side. Try to remove it and replace it the correct way.
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
Printing light strips
Possible bad fuser assemble, on this model very hard to see, have to almost take fuser out to see if worn. Also make sure gmall **** glas on top were the paper feeds over is not dusty...
Jun 12, 2008 | HP LaserJet 3055 All-In-One Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 4350dtn Printer Logo
296 people viewed this question
Seeker5211
Seeker5211
