Question about Dell Latitude D600 Notebook
Dell c610 fans stay on and won't turn off!
Ok well basically my screen stopped working last night, so i opened it up took the screen cable in and out etc... not its all up and running again, except the fans are constantly on full power aa soon as i turn it on. They wont be normal and turn on when needed. Cold you help me return them to their previous state. So that they only come on when needed etc...
Cheers
Scott!
  • Scott Burns Feb 06, 2009
    Ok that works for all of a matter of 2 seconds haha! Basically the temperature isnt working... its stuck on 85 degrees.
    Ok thanks for your help. Im just in wondering if i have knocked something inside or have caused something to break, cause this never did this before. As soon as ive turned it on from being cold it says 85 degrees. So i would say heat sensor could be faulty maybe?
  • 458 Answers
Go Here-------> http://www.diefer.de/i8kfan/index.html
and download the 18kGUI fan utility software, it runs great on dells, you can control your fans, or set it to auto, or low etc....
Posted on Feb 06, 2009
  • Garry Romaneo
    Garry Romaneo Feb 06, 2009
    You Must Be Overheating..
    You Heatsink Fins are Probably Blocked.. Dust and Debris Buildup in the fan area will eventually create a "strip" of lint that completely covers the Fan Exaust Port, When this happens, air can not escape and therefor it is forced into the motherboard area and anywhere else there is a space for the air to go... this heats up the RAM, The Video GPU, and Processor, and Overheating can happen the second the laptop is turned on - if dirty enough.
    If Dust and Clogged Fan Is Not the problem... Then Your Thermal Controller Either Onboard Or The Fans Thermal Controller is faulty..
  • Garry Romaneo
What would cause computer not to turn on when the power is loaded and the screen to stay black?
Im sorry about your situation.
Does the computer turn on??
If the computer turns on do you hear or can you see the fan working??
If the computer turns on does it stay on or does it shut down after a few minutes??
This will help us determine what is going on.
May 31, 2014 | Acer Computers & Internet
My goodman condensing units fan won't start to turn on its own
Hello, usually this is a sign of a bad capacitor. Replace the capacitor.
May 21, 2012 | Heating & Cooling
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Dell c610 no audio--after microsoft update. how
do a system restore from the last time it was working properly
hope this helps
Jul 22, 2010 | Dell Latitude C610 Notebook
My dell latitude c510/c610 failing
Sounds like the fan may be failing and need replacement. On a system that age, it is debatable whether it is worth fixing.
You can boot to he resource cd and run fan diags is you want to try and confirm
Fans can be found on EBay
May 26, 2010 | Dell Latitude C640 Intel Pentium 4-M...
The fans won't turn off !?
THE FAN RUNS ALL THE TIME, THE CPU CAN COOK AN EGG ON IT IN A MATTER OF SECONDS.
GO ON LINE TO EBAY, OR A VENDER OF THAT PRODUCT, RECONDITION ELECTO-MECHINICAIL USED COMPUTER EQUIPMENT STORE.
ROD
Feb 05, 2009 | Dell Latitude C610 Notebook
Dell Latitude C610 Laptop won't turn on
If the light comes on for three seconds and then go out ,generally means a power distrubution problem . remove the optical drive and memory from the system and try powering it on. If u get the same result , its time to take it to service tech , as your motherboard needs to be checked
Apr 07, 2008 | Dell Latitude C610 Notebook
Noisy laptop
sounds like the fan is bad in there. Here the service manual, it will show you how to take it apart.
http://support.dell.com/support/edocs/systems/latc610/en/index.htm
Dec 07, 2007 | Dell Latitude C610 Notebook
Dell latitude c610 has dead screen.
First of all, try to connect an external monitor to the laptop and see if you gen any video out.
Nov 30, 2007 | Dell Latitude C610 Notebook
Dell Latitude D600 Notebook Logo
590 people viewed this question
Alun Cox
