Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Need wire diagram jvc av-48wp74
I need a wire diagram for a jvc av-48wp74. I have a burnt resistor on the convergence board that I can not read what size it is.
  • jacques2001 Feb 20, 2009
    Can you send me the wiring manual for the Av-48WP74 ? My email is Tks.
    Problem Solver:
  • 22 Answers
I have it send me your email
Posted on Feb 09, 2009
  • 48 Answers
That should have everything you need.
Posted on Feb 05, 2009
Whats the part number for convergence chips on jvc av-48wp74
There are two of them that need to be replced as a set. They are both STK392-110 Convergence Ics you can get the original oem Ics from they are listed under the Integrated Circuit catagory you only need the one set. They also have the convergence repair kit listed for your model under the JVC repair kits the kit has both ICs all 12 resistors and the CD with step by step repair instructions.
Oct 17, 2012 | JVC AV-48WP74 48" Rear Projection...
Dear SIR Please send me the number part of Convergence Module for JVC Model AV-48WP74. THANKS FOR YOUR ASSISTANCE
I WOULD DOUBT THE BOARD IS AVAILABLE and you if you have convergence problems can have it repaired for 1/10th of what it would cost.
Only Two IC's and or one or more resistors fail on this board.
It is easy to actually get the board out of the set.
See attached photos of the board:
It uses two of the STK-392-110 chips ( A pair can be purchased on EBAY for about 12 dollars!) If one or more of the resistors are bad they are easy to locate and replace---generic part and each part on this board has a location number printed next to it.
Less than 20 dollars in parts, about 40 minutes to remove board, replace parts and put back--all you will need if it works is the JVC remote to use to adjust convergence.
If this told you something (or the photos helped you) rate this solution as, very helpful as I do this here for free.
Regards, SD TECH
view of board from back removed from set
view of board removed from set from front
view of back side of board--two stk-392-110 chips and in front of them the protection resistors
Aug 13, 2010 | JVC AV-48WP74 48" Rear Projection...
JVC AV56wp74 convergence. Resistor before ICs?
It's recommended to replace all the defective parts first because if you only replace the defective resistor, it might burnt again if the convergence IC is shorted internally. I would also suggest to measure the other low value resistors with multimeter.
Oct 30, 2009 | JVC AV-56WP74 56" Rear Projection...
Make sure you bought genuine Sanyo chips...if not goto and get theirs.
Aug 05, 2009 | JVC AV-48WP74 48" Rear Projection...
I have a jvc av48wp30 tv and need a wire diagram
Looking the convergence board from the side of the resistors (The chips will be behind the resistors), you have from de left to right:
1.5 ohms, 150ohms, 220ohms, 2.2ohms, 3.3 ohms, 220ohms, 1.8ohms, 220ohms, 150ohms, 150ohms, 1.5ohms, and dispose horizontal in relation of the other resistors (the one near to the Ic is 2.2ohms and the other is 220ohms).
Hope this helps...
Feb 02, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48 IN
Hey Zerp,
You need Convergence IC's. It is more difficult than batteries on a remote.
You access the convergence board through the inspection plate that is located behind the front speaker grill.
You remove the board, determine if any resistors are burnt, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If you live around Calgary, try me instead:
or try the find a repair person part of this website, maybe you will be lucky and someone is listed nearby.
Most rookies doing this job will cause damage and not be successful, and pay double for someone to fix their mess.
Jun 23, 2008 | JVC AV-56WP74 56" Rear Projection...
Green bent line on 48 inch jvc
Check for a burnt resistor on the convergence circuit board. This is usually what happens when the green gets distorted as the green is not adjustable only through the service menu so its either a burnt resistor or a leaky capacitor. Resistor is far more likely. Let me know if you need any further information.
Jan 24, 2008 | JVC AV-48WP74 48" Rear Projection...
Watts of the resistors convergence tbl
give me the board location numbers and I`ll get you the info you need, (next to the resistors it will be printed on the board, )example: R100, R265, R565 etc. Let me know BMW Rider
Dec 28, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
211 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
