Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Replaced heating element now oven wont work
The heating element blew up - smoke and loud popping noise and we took it out and it was obviously dead. It was replaced and now the oven doesnt work. The buttons on the front show that its working but the oven doesnt come on. my dad thinks the eoa board is bad. Model number is 790. 96424406
  • cray2 Feb 06, 2009
    a kenmore, electric, single oven. woops. guess it would have been good if i included that.
  • Anonymous Mar 03, 2009
    I also had a heating element burn through, thought it would be a simple matter of out with the old, in with the new but now the bottom replace heating element wont heat, the oven obviously turns on and the top element is heating but nothing from the bottom one I replaced, I have an older hotpoint electric oven, modle number is unreadable.
    Scholar:
  • 86 Answers
Hi what make is your oven?
Posted on Feb 05, 2009
  • Kris Seymour Feb 09, 2009
    Hi sorry i am not to ofae with these models! But the best place to start is the incomming mains. Then find where the mains electric is distributed into the appliance (I.E. the clock or main control board) Then live test the board with the correct equipment and you should be able to locate where the power source is being disrubted.
    Good luck...
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not work,
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at http://appliancehelponline.com/ovenelementvideo.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
If the element checks good it probally blew the relay on the main control board you will know this if you have no power to the element.
May 27, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I was just preheating my GE JT950 oven and there was a loud "pop" sound from the top fan, and then smoke emanated from the oven. The circuit breaker in the home is fine, as no fuses were blown. Any advice
bake element do pop when they burn out and some will act like a sparkler and burn and burn .. I would look for a bad spot in the element of the oven that you wer heating . mm
Dec 03, 2009 | GE Profile JT952 Electric Double Oven
After a "pop" - the oven no longer works
You should have thrown the breaker before moving the oven. The element likely shorted and blew the breaker. make sure the breaker is off. replace the element and plug it back in and reset the breaker.
Eric
Sep 22, 2009 | Ovens
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
355 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
