Question about Electrolux Dishwashers
Blocked dishwasher drain
The drain of our dishwasher is blocked and we have tried various chemical and mechanical unblockers. The instructions say the cyphon needs unblocking but we don't know how to do this.
    Scholar:
  • 93 Answers
First can you hear the drain pump running when the machine goes into drain cycle?
If you can then what you can do is pull the dishwasher forward and locate where the drain pipe (cyphon) is connected on the back of the machine,this is normally connected to a short plastic tube via a hose clamp.Loosen this and remove the pipe shove a hose down it and clear,replace and test it should work.Just a few pionters when a unit is not draining,first check in the botoom inside of the machine there is a filter remove and ensure this free from obstuction,also while the filter is of visually and with your hand feel for any obstruction in the machine where the filter goes.
Give this a try and let me know if this helped if it does not we can go to the next step.
Posted on Feb 05, 2009
My dishwasher did 3 beeps which meant drainage overload so I cleaned tray inside it now I get one beep every 3 seconds I can hear the water filling up but looks like the blades don't go round
Intervention of Anti-flooding system (The cycle is interrupted and the
drain pump switches on)
Could be:
  • Water leakage from the tub - sump and various connections (pump, upper spray arm duct etc.)
  • floating sensor blocked mechanically
  • microswitch faulty
  • fill solenoid blocked mechanically
  • circuitboard faulty (solenoid triac short-circuited)
  • wiring faulty.
Dado
Apr 27, 2016 | Electrolux Dishwashers
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
My dishwasher keeps flashing i30 and wont start what shall i do
In your case occurred intervention of anti-flooding system.
Displayed Error is "i30"
The cycle is interrupted and the drain pump switches on.
Could be:
connections (pump, upper spray arm duct etc.);
floating sensor blocked mechanically; microswitch
faulty; fill solenoid blocked mechanically; circuit
board faulty (solenoid triac short-circuited); wiring
faulty.
First, try to tilt dishwasher and see if leaking water from its bottom.
This is most commonly occurs.
Dado
Jan 20, 2014 | Electrolux Genuine ZANUSSI ZDF511...
Unblocking blocked websites school computers
Schools generally keep various gaming and entertaining sites blocked so that the students would not get distracted by playing games and using other sites.
Here, I will provide you a way to play Unblocked Games 77. I also prefer this site to play various blocked Sports games, Action games, Strategy games, and shooting games at restricted places.
Sep 11, 2013 | Dell Computers & Internet
Possible Clogged dishwasher
sounds like blocked pipe. if you cannot unblock yourself you will need to call a plumber
Feb 03, 2013 | Frigidaire 24 in. FDB1050RE Built-in...
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
It seems as though the water is not draining thru the hose. could there be a screen that is blocked, and if so how do i unblock it.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 28, 2011 | Kenmore 13732 / 13734 / 13739 Dishwasher
Message on Model DWU9961 - Blocked Drain How do I
Hi wait a moment pls your request is been proceeding..
Jan 17, 2011 | Maytag Dishwasher
Blocked drain message on GE GSD2800 dishwasher
pull the bottom tray out, in the back portion of the center of the dish washer there is a plastic screen looking thing, you will need to take a 1/4 inch nut driver and take out the screw pull off the cover and clean out the drain,, there is probly some food particals in there , it does havea small blade inside there to help sut up fine food that gets thru but it doesn't do it all the time ,, make sure you put the cover back on before runnig the unit
Jun 27, 2009 | GE Profile PDW8400J Built-in Dishwasher
Hotpoint FFA70S fridge drain blocked
PEACE,
ngfam1 at your service,
Do not use sink chemicals!!!!!!!!!!!!!!
In the hard ware stores or home depot they have small short,
snakes that are flexible and thin that can go in the hole to clear it!
Tell the home depot guy to help you find what I'm
telling you to buy!Print this out and show him what I spoke of!
Bless you,
Please give me a good rating before you signe off
Sep 04, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Dishwashers Logo
406 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
