Question about Logitech (9633260403) Game Pad
Spiderman WoS and Incredible Hulk (2008) don't respond to gamepad
In control panel-game controllers-testing, my gamepad reacts exellent, but when i try to set control buttons,game launcher don't recognize game pad
  • 126 Answers
Its not problem with your gamepad. Its the problem with game both games. It has a bug problem. It cant install gamepad. dont try it again & again as it may damage the game pad internal configuration. pls rate for me .
Posted on Feb 13, 2009
WHEN I RUN THE INCREDIBLE HULK IT SAYS PLEASE INSERT THE CORRECT CD ROM
copy the game crack to the folder where u have copied the game
Mar 14, 2013 | Sega Incredible Hulk
Right joystick works fine going left to right, but is very sluggish moving up and down, and occasionally doesn't respond at all
1-try rettting game's control layout back to default...you might have changed the layout 2-is this problem happening in other games as well? if it does, then we can consider taking the controller for repair 3-there is always ebay and amazon to get you a new controller 4-do you have a wireless or usb adapter to connect the xbox controller to the pc? in windows 7 you can use the gamepad as a gamepad and in "callibration settings" you can test the buttons
game on!
Feb 24, 2011 | Microsoft Xbox 360 Controller
Need the hulk video game manual.
type 'hulk sega manual' in google 4th site from top download your manual
Jan 15, 2011 | US Gold Ltd. The Incredible Hulk for Sega...
Hold a thrustmaster dual trigger 3-in-1 gamepad but the game does not recognize what to do please help
download Xpadder. An exelent software to use on any software.You can surf in your browser with it or even play miniclip games with; just EVERYTHING.The software use your gamepad as a keyboard and mouse, I personaly hosted the file myself in my megaupload account so here it goes:
http://www.megaupload.com/?d=LORO7H9Y
Nov 02, 2010 | Guillemont Thrustmaster Dual Trigger...
My logitec precision gamepad is not working in NHL 2009.
Thank you for your time and attention. Can I use a Logitech Precision gamepad to play online video games? I plugged in the USB in the front of my pc tower, but I can't control the games with it. The games only respond to my keyboard. Is there something I need to do or is it that I can't use it to play online videogames? Please help.
Mar 04, 2010 | Logitech Precision USB Gamepad PC Game...
Start does not work on Incredible Hulk for PS3
It's the game data. It's corrupted.
Check under GAMES, Game Data, just delete the Hulk stuff and then reopen the game.
That should clear the problem.
Jun 17, 2009 | Sony The Incredible Hulk for PlayStation 3
Problem with gamepad
For checking its full functionality follow the procedure. Go to: ->control panel ->game controllers There u can see USB GAME CONTROLLERS or some name. Select the controller & go to its properties. 1.) on the test tab check all the buttons 2.)On calibration tab check joystick - x/x 3.)on effect tab check the vibration .  Don't spoil the settings of program tab. If any problem persists contact me. pls vote me. thank you
Feb 03, 2009 | Video Game Consoles & Games
The Incredible hulk ps2 game
tap the button rapidly indicated on the screen so hulk can now move around
Jan 09, 2009 | Vivendi Universal The Incredible Hulk:...
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Logitech (9633260403) Game Pad Logo
1,171 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
