Question about Hitachi CP-X985 Multimedia Projector
Hitachi line problem
My Cp-X985 projector began showing horizontal lines in the left corner about 2 weeks ago and the problem has now spread through out the whole picture. The image looks double between the lines, and makes it impossible to read words off of. I am hoping that cleaning it will work but wont know until I get it down. Please Help!
  • mmacado Feb 14, 2009
    I am having this same problem. Is there any other solution? A filter that can be cleaned or service manual for this project?
  • 1,602 Answers
The horizontal is given out ont the project it will need to be service. or the part ordered and you fix it your self.
Posted on Feb 05, 2009
Vertical line
the LCD is not work well
you can do follow these:
1,reconnect the LCD cable (It is connected to the motherboard and LCD screen)
2,if the vertical line is still there,it means that the LCD is bad ,you need a new LCD
Feb 09, 2014 | Hitachi Ltd Projector, Hitachi,...
Screen flickers and color wont show
What kind of cable are you using, and how long is it? Does it work for connecting the PC to a monitor? And are there any splitters on the line?
Jan 30, 2014 | Hitachi CP-X253 Projector
Having trouble with Y-VGA splitter, connecting to both Dell 380 computer and projector at the same time - Dell monitor cuts off when connected to projector.
Sounds like the the monitor detect line is causing your issue. The Hitachi CP-X250 has VGA in & out. Hook the Dell to the VGA out port of the projector.
Apr 25, 2011 | Hitachi CP-X250 Multimedia Projector
How to clean air filter in HITACHI CP-X385
Hi there
Look at the bottom of the Projector , you'll see a thin grey line with two edges on it. That is the filter. Grip on the sides and gently pull it out.
Mar 17, 2008 | Hitachi CP-X385W Multimedia Projector
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hitachi CP-X985 Multimedia Projector Logo
288 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
