Question about Lexmark X4270 All-In-One InkJet Printer
"Black Cartridge Missing"
Tried 2 different new cartridges, unplugging machine, canned air where cartridge meets machine. We can fax out, but machine just rings on incoming faxes. Had the machine for almost 2 years.
  • Anonymous Feb 05, 2009
    ujk
    President:
  • 2,976 Answers
You have to go into the setup menu and set it to answer on incoming faxes.
Posted on Feb 05, 2009
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark X4270 fax machine, and I have just got a new black ink cartridge. The old one was a lexmark 71 the man at Quill said to get a lexmark 75 hi-yield. so I did my machine keeps saying black...
Did Quill sell you a "OEM" (Original Manufacturer's Equipment) or a cartridge a third party cartridge?
If it is a third party ink or cartridge, then that's your problem. Lexmark does not condone the use of third party ink or cartridges. This is considered to be product tampering by Lexmark and they will void the printer warranty if damage results from the use of these type cartridges.
I do apologize for the bad news, but I do ask that you do not shoot the messenger. :-)
Jul 03, 2009 | Lexmark X4270 Printer
Wrong black cartridge error message
Probably have a defective cartridge. Are you filling this yourself? Black cartridges are pretty cheap might be easiset to purchase a new one and get yourself back up and going.
Hope this helps
TankMurdock
Apr 08, 2009 | HP 920 Plain Paper Fax
Fax will not print after installation of new cartridge
Look at your NEW print cartridge again, very carefully. I'll bet there's another piece of tape on the bottom of it. That's what happened to me.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Cannon Laser Class 730i fax saying replace cartridge/when full
The machine is out of adjustment. Open the left panel and adjust the pot near the rear of the machine and turn it to about the 11 o'clock postion.
Feb 15, 2008 | Office Equipment & Supplies
Machine will not reset after toner replacement
Info code 45 really means Toner cartridge is not installed.Info code 41 is out of toner & code 43 is toner getting low. There are three connection points inside of the fax machine that tell the machine that a cartridge is installed. Open the cartridge door & remove the cartridge. Verify that the metal tabs on the right hand side above the drive gear stick out far enough to make contact with the cartridge. There should also be two wires that are located on the left hand side that also make contact with the cartridge. Try putting your used/empty cartridge in & see if your info code changes to a 41 or 43.If not, you may have a broken connection. I have found that some compatible cartridges for the panafaxes are missing metal tabs that make contact with the connectors. Compare a cartridge that worked to the one that doesn't to see if it's missing metal tabs. This is not an issue if you are using OEM. Good luck! I can be reached by email if you have any questions. bspier@carlsonsupplies.com
May 23, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Lexmark X4270 All-In-One InkJet Printer Logo
94 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
