Question about Zhone Router
Problem setting up zhone router
I was trying to set up my zhone router when i entered the wrong IP address for the LAN settings. everything kinda went bad from there, I tried to start over but i cant even get to access the IP address when i enter it as the URL in a web browser. I need help man!
  • Anonymous Mar 30, 2014
    FOR ME TO MAKE CALLS
I reseted the router and started over.
Posted on Feb 06, 2009
I have a zhone 6211-I3-200-ADSL2+CPE w/phone filter. I am trying to connect 2 computers (1 laptop, 1 desk top) to a linksys WRT 150n wireless router and cannot get the wireless connection to work. It shows...
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 03, 2010 | Zhone 6211-I3-200 Router
Need to change the NAT setting on my Zhone 6218 DSL modem. How?
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
Jul 16, 2010 | Zhone (6218-I2-200) Router
I need help changing my mtu setting for my 6212-13-200 Zhone router
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on WAN settings and change MTU settings then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 12, 2010 | Zhone (6218-I2-200) Router
How do i get the wep key from this router. I got mine from NorthState Communications.
A brand new wireless router will not have and encryption set.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 12, 2009 | Zhone (6218-I2-200) Router
Entered the wrong ip address
Different manufacturers have differing setup so without the details of the make and model of the router in question it a little hard to help.
Most routers will have the ability for you to reset it to factory default by a button or such on the unit itself - refer to the install documentation that you got with the modem - if you dont have it you may need to aska friend to borrow their PC and access the manufactures support pages for help.
Jul 13, 2009 | Computers & Internet
How do i change my lan IP so my router works
Hi!
Start by opening up a web browser (it doesn't matter if it can get to the internet or not, as long as its from a PC connected to the router) and, assuming the LAN address is still the default, goto the address "http://192.168.2.1" click on "login" and you will be prompted for a password.
Again, assuming everything is still default the password is not set and you can just click "Submit."
On the left side you will see a menu, underneath LAN click on the "LAN Settings" link. You will be presented with a page were you can set a new IP address for the router. Once you change the IP and click "Apply Changes" the IP of the router will be changed. Once the device finishes restarting you will now have to use the new IP address you just entered, in you browsers address bar instead of 192.168.2.1, in order to see and configure the settings of your router.
Hope this helps! Here is a link to the manual for product incase you get stuck. The juicy stuff you want is on page 33.
Mar 26, 2009 | Belkin (F5D5231-4) Router
Great problem with router zhone 6218
i assume that you're not prompted with the log in screen. if so, you need to check if your computer is properly connected to the LAN/ethernet port of the router (Note: you need to use a hardwired computer if you want a stable connection while checking your wireless settings) and if it has a valid ip address which shoud be within the subnet of the router's ip address (Note: by default the router's ip address is 192.168.1.1 and "admin" is the default username and password)
if you're not sure of the current ip address of the router. go to command prompt and type ipconfig. it'll list there the default gateway which is the router's ip address.
now if you have checked that the computer has a valid ip address and it is properly connected to the router but you can't still access the router's page, there could be a program that is blocking the connection. try to disable any firewall or any antivirus programs installed on your computer.
hope this'll help you. you can click here for the manual if you would like to read some more about the router.
ciao!
Aug 13, 2008 | Zhone (6218-I2-200) Router
Where can i log on to the router or change its password?
To access the router's configuration you need to type its IP address into a web browser. The default IP is 192.168.1.1 but if that doesn't work you can find it out with the following steps:
  1. Go to Start->Run
  2. Type "cmd" without the quotes into the box and press Enter
  3. type "ipconfig" without the quotes into the larger black box and press enter
  4. The number across from the "Default Gateway" is your router's IP address
I hope this helps!
Jun 13, 2008 | Zhone (6218-I2-200) Router
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Zhone Router Logo
264 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
