Question about Panasonic CQ-DVR909U Car DVD Player
Connection external gps box to car video in-dash
I bought DP VIDEO car stereo with 7" monitor model DBD803BL. I'd like to connect external gps box to this device. Tell me, please, what kinds of external gps navigation boxes I can use and how?
3 Suggested Answers
SOURCE: DP Video car system to play video
look at the install diagram(wiring codes) that came with the unit. if it has a wire that's designated for the parking brake (allowing you to only watch dvds while brake is engage) take that wire and instead of hooking it up to the parking brake, ground it or put an in-line switch between wire and ground so you can turn that function on and off. warning!!! watching while driving is illegal in most states
Posted on Jan 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: poor AM car stereo reception with new DP AudioVideo player
AM.... what the heck is AM??? LOL
Check the antenna connection behind the radio to be sure it is taped and not touching ground. Also the antenna & cable running to it for worn spots in the shielding, or corrosion.
I think (based on knowing how manufacturers do things at times) that their is a very cheap universal chip type tuning system in play here on the order of about 10 cents value that many manufactures are probablly incorporating these days. What I did to solve this annoyance was to purchase (after many tests) a SHARP brand walkman type AM/FM hand unit that has really good AM and jack it into the preamp section before my crossover (added an extra input via Y-adapters) and use Ni-metal-hi batteries that can be recharged. I get about a week out of the 2 AA cells. I also had to build a rather good cable (shielded) to go from the unit to the 1/8 jack to cut noise a notch more. This has proven a good situation for me.
With this knowledge, I wonder what head units actually have good rejection circuitry and great gathering power for amplitude modulation?
Posted on Jan 08, 2009
  • 30 Answers
SOURCE: Trak error or Disc error
look put the brake wire to ground
Posted on Jul 15, 2009
Nitro car stereo manuals
Need settings code for an Nitro BMWX-4756 300Watt 7" Touch Screen Monitor In Dash Din DVD CD AM FM for the gps, settings it's a 4 digit code to change GPS settings
May 01, 2015 | Nitro Bmw-4741t In-dash Touch Screen...
Wont connect to external display windows 7
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Feb 06, 2013 | Acer Aspire 5560-Sb659 laptop
My samsung q320 will not detect my projector
Connecting an External Monitor or Data Projector
Jan 12, 2013 | Samsung Q32032P PC Notebook
I am trying to hook up my cable box so i can watch tv.
At the cable box input, connect the cable (probably labeled "Cable In" or "Signal In").
Depending on the cable box model and available inputs on your TV, connect one of the following (listed in descending order of video quality). Colored phono plugs must match the colors of the plugs on each end.:
  • HDMI (a single rectangular connector at each end - sometimes you need to connect the Audio separately with a two - line cable with red and white phono plugs).
  • YPbBr, AKA Component (Cable with Red, Blue and Green phono plugs, plus a separate Red and White cable set for Audio).
  • S-video (a single round connector and separate Red and White audio cables).
  • Composite (Yellow video cable plus Red and White audio cables, usually sold as a single set).
  • RF out on the cable box connects to ANT or Cable In on the TV with a coax cable.
The various options are always grouped in some manner on both the Cable box and the TV. On the TV, note which input set you use, for example, "Component 1". This is the input you will select to watch whatever channel you select on the cable box.
An unused output on the cable box can go to a video recorder. Some cable boxes may permit setting up two different channels for this purpose; others will only put out the signal from one channel at a time on all outputs.
You may, if you prefer, connect the audio cable from the cable box to a stereo receiver instead of the TV. Usually people connect the audio to the TV, then connect another audio cable from "Audio Out" or "Monitor Out" on the TV to the stereo receiver. That way the sound is from whatever video source is currently selected, and the TV remote control can be used to set the volume. TV sets with this option usually have a setting to turn off the internal speakers so you hear only the external stereo speakers.
Feb 05, 2011 | Televison & Video
The monitor has jagged lines going through the picture in both units. These units are in the head rest of the car.
Check the video module. Generally, it's under one of the seats since the cables are usually only 6' long. Check the video connections at the module. ( The box is usually 7"x7" and about an inch tall) If all your cables are tight and you can't get the dash unit out, to test the headrest monitors, if you've got a small tv with video input, plug it into the module, if it's the same, you know it's the module or the deck. Chances are it's a loose video connection on the input side of the module or a loose connection on the video output of the deck or DVD, whichever you have. Hope this helps
Jun 23, 2009 | Audiovox D1020 Car DVD Player
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
No video
Hello I've just received an in car GPS system, and video/audio player from Japan. I live in Barbados, and I dont speak or understand japanese It is a Pioneer Carrozzeria AVIC-T1(CPN1800). I plugged my DVD player to it but ilke the previous writer, I am getting audio but not video. Can you give eny information concerning how I might remedy this.
Jan 25, 2007 | Pioneer AVX7300 7 in. Car Monitor
Panasonic CQ-DVR909U Car DVD Player Logo
716 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
