Question about BUSlink Televison & Video
Bush LCD26TV005 no power (Checked switch, power gets to PSU PCB)
Hi My Bush LCD26TV005 was working fine the died! then came back on for 2 hours, now completly dead (not even power led on or flashing) my first guess was the power switch. but i've tested it, power gets to the power PCB. but thats it, has anyone had this prob befor? now thinking a voltage resistor may have blown but thats a guess as i have no way to test them, if you can help please let me know, thanking you very much in advance,Stu J
dhiman
  • 115 Answers
SOURCE: My MovieTime die after two LED flash for a second after power up.
Check the Lamp and replace if that is damaged.send for repairs if the Lamp is okay.
Viren
Posted on Nov 27, 2007
chrispurs1
  • 372 Answers
SOURCE: Repair to Bush LCD26TV005 TV
Hi.
Try this site.
http://www.chsinteractive.co.uk/
They supply spares to general public.
Chris..
Posted on Jan 11, 2008
zjut
  • 106 Answers
SOURCE: relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Posted on Mar 23, 2008
Fix-4U
  • 293 Answers
SOURCE: HP LCD Monitor w1907 Blowing fuse - no display
Sure, you can testing it both ways... in-circuit or out.
Posted on Dec 01, 2008
  • 1525 Answers
SOURCE: hotpoint aquarius wf100 completely dead
have you check the glass fuse on the circuit board it might be at the bottom
shaun
Posted on Mar 20, 2009
I have a BUSH LE-32GE11E Flat screen TV. The standby light is very dim red and then the ON light is BRIGHT BLUE, but the TV won't power up. Is this a problem with the PSU PCB?
I'd test all the different voltages produced by the power supply board first. If everything checks OK there, then the main board is faulty. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
May 10, 2017 | Bush Televison & Video
24inch Bush smart TV/DVD not working.
Could be an open internal fuse or power supply failure
Jan 09, 2017 | Bush Televison & Video
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
When I switched on my Bush Television this morning there was no sound, what do I need to do to get it back. This has never happened before. Thank You
Switch off power remove plug and keep aside for an hour. Now after reconnecting if there is no sound you need to test the audio input and audio output to confirm if the fault is relative of the preamp or the power output amp. connect an input source to TV and another from TV output to Amplifier.
Once confirmed then the section can be checked , for power supply failure or the processing section IC.
Sep 15, 2011 | Bush Industries IDLCD15W008HD LCD TV
Bush tv frequently turning itself off
make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
Dec 21, 2009 | Televison & Video
Picture is not coming ?
it can be the wire getting short from the main board towards the power supply board which helps to get the picture that needs to be checked and replaced to get the proper picture.
Jan 17, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Bush LCD TV No picture but sound
replace 2 large caps on psu panel 1000uf caps lt feed to inverter panel caps are on right hand side of psu panel
Dec 15, 2008 | Televison & Video
Hi.
Try this site.
Chris..
Jan 11, 2008 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top BUSlink Televison & Video Experts
Electro Med Services...
Are you a BUSlink Televison and Video Expert? Answer questions, earn points and help others
