Question about Kenmore Elite 45986 Front Load Washer
Repair do it by myself
Hello I wrote you week ago about problem with my Kenmore HE5t F11 error, find part.Thank you for helping saving money.I already got the part and now I need to know if you can help me do the repair by mysel. Can you send me a video or step by step instructions?I'll really appreciate.ThanksRodrigo
  • farofino10 Feb 06, 2009
    I'm writting to thanks my expertise helping me with my issue.
    I repaired the washer yesterday and it's working ...........
    I could not believed that I saved so much money with your help.
    I really appreciated.
    Rodrigo
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    I have a Kenmore He5t steam washer. I got the F35 code again, so I automatically ordered and replace the pressure switch again. did not fix the problem. I have checked and cleaned the drain basket and
    Unfortunately you spent money unnecessarily, and before making any additional errors; it would be best to have a trained technician with knowledge of the washer, service the system.
    Jan 18, 2015 | Kenmore Washing Machines
    When I run any cycle, it is squeaking and making noises. It sounds like the dryer cylinder is loose. Kenmore Elite He5t Gas Dryer
    Here is a tip that I wrote about dryers and noises...
    It will help you determine what is happening there...
    Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
    heatman101
    Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
    Dec 31, 2010 | Kenmore Dryers
    2006 dodge stratus overheats intermintently ie runs fine for a couple of weeks then overheats the runs fine for another couple of weeks. Already change thermostat and coolant
    Hello kmunstis and thank you for asking your question, on Fixya.
    Here is a simple process that will walk you through a few steps that will pinpoint the overheating problem on your 2006 Dodge Stratus, without even using any tools. It has helped millions of people, and I am certain that it will help you, because I wrote it for people like you. So here is the link:
    How to diagnose your overheating 2006 Dodge Stratus
    You might want to pay closer attention to the fans section of these instructions.
    Get more great, money saving, tips and tricks about your vehicle from: twitter.com/acoates23234
    Thanks for the vote, and good luck!
    Jun 02, 2010 | 2006 Dodge Stratus
    If the problem is, indeed, the Motor Control Unit, you can find this part at appliancepartspros.com for about $243. Still a bit expensive, but far less than the $800 repair quote you got. Go to the website and search by part number. Use part number 8183196. I hope this helps you. If you require further assistance, please let me know.
    Feb 01, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE5t Washer Error Code F11
    F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
    Jan 03, 2009 | Washing Machines
    F11 code on Kenmore Elite Front Load Washer
    Although it is true that an "F11" error code indicates a problem with between the CCU and MCU. The majority of the cases turn out to be a problem with the CCU or the wiring harness. A failed MCU is generally indicated by an error code of "F06". The following link explains your error code and basic tips on troubleshooting:
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    I would like to know how your 2nd tech was able to "determine" the cause without a multimeter. The cheapest I was able to find both the parts you mention was repairclinic.com. The prices are still relatively high, but you will save - some. I hope you find this information helpful. Let me know if you still have questions or concerns.
    PS Sometimes these washers will experience momentary glitches which requires a reset of the CCU. The manufacturer recommends unplugging the appliance for at least 30 minutes to do a reset. If you haven't thought of this already, you may give it a try to see if this clears your problem. It could save you from an expensive repair...just a thought.
    Oct 06, 2008 | Washing Machines
    Kenmore Elite 45986 Front Load Washer Logo
    151 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
