Question about Sony HVL-F32X TTL Flash
Sony hvl-f32x I have broken my hotshoe.how do i open up the unit to replace the part. where also do i get the part from.If not possable to repair myself where would be the best and quickest repair centre in britain. i live in Wqles.
  • Print Mama May 11, 2010
    Where exactly is it broken at? Is it still under a warranty? How many pins does it have on it or how many pins does the camera that your using it with?
I managed it by buying a broken (non-working) F32X from an auction service for something like 5 bucks. I just made sure (by looking at the photos) that the hotshoe was intact.
Here's how to disassemble and replace foot (I got to this by trial and luckily no error ^^).
  1. Unscrew 2 small screws located under the battery flip cover.
  2. Put the lamp (moving part) in the upright position.
  3. Unscrew 1 small screw above the infared sensor (below the main lamp part which you moved to the upright position).
  4. Remove the cover of the infared sensor by gently pulling forward.
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Then pull the pieces apart gently. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  6. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  7. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
  8. Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Took me about an hour to do this (most time was spent on trying to figure out how to disassemble the lamp), and the lamp works perfectly.
Warning: better test disassembly on the replacement lamp, since even if you break it, all you need it for is the hotshoe, so you can practice on it. Only after you learn how to disassemble the F32X do this on your working lamp.
Hope this helps!
-- Tomasz Andrzej Nidecki (tonid)
Posted on Feb 15, 2011
I have been putting new expensive batteries in but is still spends a minute flashing orrange then flashes a red light and says "error" as if my batteries are dead??
Sep 11, 2011 | Sony HVL-F32X TTL Flash
Sony HVL-F32X manual
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this helps. Thanks for using FixYa
Sep 06, 2010 | Sony HVL-F32X TTL Flash
Hot shoe plastic section broke on flash unit
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Pull them away from the casing just a tiny bit and use something to keep them in this position (I used 2 small nails). Then pull the pieces apart gently.
  6. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  7. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  8. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
Hope this helps!
Jun 17, 2009 | Sony HVL-F32X TTL Flash
Broken part
This part, the 'hot shoe assembly' is much stronger than it looks and holds all the weight of the flash mounted to the camera in those 2 little slots.
Yes, you'll need to replace it.
Are you comfortable with electronics and small components. There are small springs and pins/ball bearings/contacts in there when the cover is removed and wires may have to be soldered in place (I can't remember if there is a plug for those wires inside).
Try here to buy the part you need or contact Sony service (I'm assuming you're in the USA):
http://esupport.sony.com/US/perl/model-accessories.pl?mdl=HVLF1000
Keep us informed if this was good or you need further help.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 06, 2009 | Sony HVL-F1000 TTL Flash
My flash won't charge. the yellow charge light won't go off when the camera is charged. The flash will pop open but won't flash. I have purchased and installed a new battery but it didn't solve the...
Either the internal thyristor charging circuit has failed or the flash capacitor is unserviceable.
Neither fault is worth repairing. Buy a small auto-exposure flashgun and use it in the hotshoe; they're dirt cheap and there are plenty of used ones for free if you ask on FreeCycle.
You'll need to go into the DSC-V1 menus to enable the hot shoe on the top plate of the camera and you'll find that even the smallest and least specified flashgun will give better results, but try to get one with at least two aperture settings within the range f2.8 to f8. Anything outside that range is useless to you as that's the entire aperture range on the DSC-V1. You'll also need to ensure that when taking photos, the camera is set to the same aperture as the flashgun. To do this set the camera mode switch to "A" for aperture priority mode and use the thumbwheel to select the correct aperture, the camera will choose the appropriate shutter speed. You can also use "M" for manual mode in which you set both the aperture and choose the shutter speed. At night, choose 1/60 but the actual exposure will be measured in the thousandths of seconds in which the flash is illuminated.
If you're rich or lucky you'll get a Sony HVL-F32X flashgun; it dwarfs the camera and is very powerful but everything is fully automatic with no manual overrides. For this flashgun, the hotshoe menu setting must be "OFF".
Nov 20, 2008 | Sony Cyber-Shot DSC-V1 Digital Camera
Can;t turn the tightening knob to mount the flash? Maybe the pin lock?
I'M UNCLEAR AS TO WHETHER YOUR ISSUE IS WITH THE LOCKING PIN OR THE COLLAR. STANDARD FLASHES, WITHOUT A "LOCKING PIN", A PAIR OF CHANNEL LOCK PLIERS CAN BE USED, AFTER WRAPPING THE JAWS WITH SOMETHING GIVING, LIKE ELECTRICAL TAPE, OR WRAPPED RUBBER BANDS. THE COLLAR CAN USUALLY BE LOOSENED IN THIS MANNER, IF IT HAS "BOTTOMED OUT" OR GOTTEN STUCK ON ONE END OR THE OTHER OF THE THREADED FOOT SUPPORT. IF YOUR ISSUE IS WITH A "STUCK PIN" THEN PLEASE DISREGARD THIS ADVICE.
Sep 25, 2008 | Sony HVL-F32X TTL Flash
Users manual
Hi - You can download the manual from the link underlined in blue below:
HVL-F56AM
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 09, 2008 | Sony Cameras
Can a hotshoe flash be installed on the Sony DSC-H5? If so what is the part number and how is it done?
Hey there Idfire, the part which you are looking for is the Sony HVL-F1000 . It comes with a mounting plate which attaches to the bottom of your camera via the tripod connection. The hot shoe is built in to the bracket, seating the flash to the side of the camera. It connects via the ACC port on your camera. I will provide you with a link to the details:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HVLF1000&LOC=3
If the link doesn't work, please just copy and paste.Hope this helps. Good Luck!
Feb 28, 2008 | Cameras
Broken flat ribbon cable on SD 28 flash
Hello, after breaking mine this morning I was able to fix the flash so It can fire from the hotshoe.
Any automatic TTL features will still not work however atleast you will be able too fire in auto, and manual modes.
I simply opened the flash by taking off the hotshoe, and then swiveling the flash head 90 degrees to expose the four screws there. You need only remove the two screws from the front side of the unit.
Open the battery door and gently pull away the front case (Be careful there are several delicate ribbon cables that you do not want to snap. From here you can either unscrew all the ribon cables to free yourself room to solder or try and dodge them.
You should now be able to see the rear side of the PC sync socket. There is a blue wire that joins the outer edge of the socket - this is ground. Solder onto this point and join onto the top left circle of the PCB board of the hotshoe. (Opposite corner from where the ribbon cable attatches) There are copper circles exposed on the pcb for easy soldering.
Next, return to the rear of the PC sync socket and note the orange wire coming from the centre pin. Solder a wire to this point, and then down to the hotshoe PCB and to the circle that joins to the centre pin of the hotshoe. (Trace the circuit paths)
Sorry I did this about 30mins ago and I'm remembering this out of my head.
Goodluck
Jan 07, 2008 | Nikon SB-28DX TTL Flash
Sony HVL-F32X TTL Flash Logo
369 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
