Question about Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI
Cleaning of a Yamaha keyboard
I have a PSR Yamaha Keyboard (not a full size) that is getting dusty and needs cleaning. Some of the keys are sticking a little bit. How do I clean it?
  • fmr888 May 11, 2010
    have you tried a can of compressed air?
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Posted on Feb 10, 2009
SOURCE: No sound on Yamaha PSR-275
make sure its not in pc mode
Posted on Aug 23, 2008
robocop
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to http://www.yamaha.co.jp/manual/english/index.php. There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
SOURCE: How do I take apart Yamaha PSR-280 keyboard to clean keys.
There are 17 screws on the underside of the keyboard that need to be removed. The base cover can then be removed. This gives access to the keyframe assembly which can be removed.
Posted on Feb 08, 2009
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
Can you find for me memory card for YAMAHA PORTATONE PSR 2000.
Posted on Mar 18, 2011
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
Some of the keys do not play on our Yamaha PSR-330. How can we fix that?
The key contacts have gotten dirty. The contacts are CONDUCTIVE rubber pills that are pressed onto circuit traces on the circuit board under the keys. Onehas to dis-assemble the keyboard very carefully noting the size and location of all the screws and using great care of the cables that connect the top and bottom of the case.
when you remove the keys, you will find silicone rubber strips with the black pills underneath, two pills per key.
Clean these with ONLY 99% isoprophyl alcohol and Qtips as well as cleaning the circuit board traces they contact.
Carefully re-assemble the keyboard.
Jan 09, 2011 | Yamaha MM6 Mini Mo Keyboard Pro
Yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Jul 22, 2010 | Yamaha Full-Size Keyboard
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Jan 27, 2009 | Yamaha Full-Size Keyboard
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Aug 31, 2008 | Yamaha Full-Size Keyboard
Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI Logo
1,008 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
