Question about Visioneer OneTouch 8600 Flatbed Scanner
Scanner is locked
Visioneer 8600 ----- computer has windows XP
message says scanner is locked. have moved the lock button on bottom of scanner to unlock several times - still get locked message.
  • andymere Apr 06, 2009
    I have the same problem with the same exact scanner. It worked the last time I used it, so maybe the lock button broke? Turning it off and unlocking it does not work. Is there a way to open it and permanently unlock it?
  • 490 Answers
Pls try locking and unlocking when power is off. S. Mohan
Posted on Feb 06, 2009
5800usb says there is a lock on the bottom of the scanner. to click OK after you have unlocked the scanner. I do not find a lock anywhere on the scanner
There is no lock on the Visioneer 5800 USB scanner. I had the same problem with my 5800 and finally noticed that the scanner lamp was going bad. I replaced it with a good lamp out of an old Acer parallel port scanner that even had the same plug, noticed that an older HP that I have sitting around would have interchanged as well. My 5800 now works great and has been tried on both 98SE and XP with SP2.
Dec 04, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
Scanner says it is lock, but it isn't
I had the same problem. The scanner car is stuck on the travel rail. Disconnect the scanner and remove the top. Turn over and remove 4 screws holding top to bopttom body. Turn right side up and push in very hard on the lower riight side of body to release snap in holding top to bottom. There are four snaps, one at each corner of scanner. Do the two rear snaps next. Then the left front should slip off. Unfold top toward front so as not to pull butoon wires out of track in bottom body. Clean 1/4" rail at rear of scanner and apply small amount of vaseline. Move car by turning gears at left rear to get to all of the rail. Reassemble. Happy scanning.
Jan 15, 2009 | Visioneer OneTouch 9220 USB Color Scanner
8600 scanner won't power up
Pls check the power adapter. If you have a multimeter, pls check the output voltage of the power adapter.  S. Mohan
Sep 23, 2008 | Visioneer OneTouch 8600 Flatbed Scanner
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
Jul 25, 2008 | Visioneer One Touch 7600 USB
How to unlock Visioneer OneTouch 5800 Scanner
i was getting this message when i was using the wrong power supply, i used a diffrent power supply and restarted the computer and it no longer says it, so i couldnt tell you exactly which one made it work, but now i get a box telling me i dont have enough disk space??? any anwsers for that??
Jun 25, 2008 | Visioneer OneTouch 5800 Flatbed Scanner
Unlock
Most scanners shipped have a lock on them to prevent the top from opening up and damaging the glass. This is a screw type mabey other but a penny fits in mine. This may not be the case for you but look in your manual to find the unlock device.
This will also in some scanners prevent the stepper motor from moving in transit . The stepper motor is the device thats makes the bar slide up and down to scan the page.
Hope this helped some.
Kevin
Dec 30, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Visioneer OneTouch 8600 Flatbed Scanner Logo
233 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Mark Gough
Ed Mac
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
