Question about Dacor Preference SGM466 Gas Cooktop
SMEG gas hob ignition problem & oven turbo fan problem
Our SMEG SUK91 cooker has an LPG gas hob with 5 rings. The electronic ignition works fine, sparks well, but sometimes almost immediately after the gas has been lit the flame goes out and is difficult to reignite. The flames aren't as high or powerful as they used to be. The gas tank is full and we don't have any problems with gas pressure when using the boiler & gas fire. Is there a simple solution I can do to try and cure the problem? The turbo on the electric oven has also stopped working. Any ideas? Thanks. Lee
  • 222 Answers
SOURCE: No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Posted on Dec 02, 2008
  • 222 Answers
SOURCE: injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
  • 222 Answers
SOURCE: Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Posted on Jan 11, 2009
SOURCE: Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Posted on Apr 28, 2009
heatman101
  • 43501 Answers
SOURCE: I have a 5 burner
The switch behind the knob is bad..
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Installing Smeg Gas Hob PGF75-3 Ultra Low Profile.
yes u can install it at the top of the drawers but check the gas connection before closing the drawers to make sure ther no problem,the inlet gas connection is in rigth side facing to u.
Nov 28, 2008 | Smeg Cooktops
Injectors for hobs convert from LPG to natural gas
Nov 21, 2008 | Cooktops
SPV577x Hob
i think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Feb 19, 2008 | Smeg 27 in. SPV577X.1 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Dacor Preference SGM466 Gas Cooktop Logo
868 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
