Question about Street Glow Streetglow Streetglow H894 Headlight Replacement Bulbs
Headlight replacement How do I access and replace the headlight bulb on a 2004 chysler pacifica?
    Brigadier General:
  • 5,158 Answers
Should be able to access them from within the engine compart ... you may need to remove the battery if it's on that side.... and don't put your fingers on the bulb... that will shorten it's lifespan
Robert
Please take a moment to rate this solution.. thanks
Posted on Feb 05, 2009
2004 chysler pacifica at random points when driving it wont let me go over 2500 rpms
Sounds like your catalytic converter is clogged replace it and find the cause
Jul 21, 2015 | 2004 Chrysler Pacifica
Looking for the location of the water pump on a 2004 chysler pacifica and a diagram for repalaceement
`The water pump is inside the timing cover and is run by the timing belt. If the water pump has been leaking I would also replace the timing belt and check the belt tensioner carefully.
Jul 02, 2011 | 2004 Chrysler Pacifica
How difficult is it to replace the car battery and the left front headlight in a 2006 Crysler Pacifica Touring car.
Both the battery and the headlights are easy to access and replace. For the headlight, you replace it from the engine compartment. Basically remove the cover (about 3 inch diameter rubber) reach in the access port and you can find the light's housing. Twist to unengage it and you can pull the housing out. The light bulb will be exposed and simply pulls off.
Feb 15, 2011 | 2006 Chrysler Pacifica
How to change a headlight bulb in a 2006 Chrysler Pacifica
Most all bulbs today are replaced through the back of the lens assy. Youll need to look under the hood and find the light sockets. then you can turn them 1/4 turn to unlock them and pull out. New lamp should not be touched with fingers, install is same, plug new lamp into socket, insert into reflector and turn to lock.
Oct 21, 2010 | 2006 Chrysler Pacifica
How do u get to the low beam bulb to change it on the 2004 chrysler pacifica
Take out two screws above headlight under hood. Pull headlight forward remove rubber cap reach in with real small hands or needle nose pliers remove bulb with a twist. Insert bulb same way after you wipe it with alcohol replace rubber cap push back in and replace two screws.
Nov 02, 2009 | 2004 Chrysler Pacifica
Replace headlight bulb
you should not need to take housing out.
Oct 18, 2009 | 2005 Chrysler Pacifica
How to replace headlight bulb hyundai elantra 2004
yes , you need to remove the headlight cover from the back after u move the bulb conector then there is a holder for the bulb u need to push down then move.
i hope it help ,,,, thanx
Mar 16, 2009 | 2004 Hyundai Elantra
How to remove the headlight lens 05 pacifica?
If I remember correctly there a a couple of nuts under the hood on each side that you have to remove and then you can swing the lens assembly out for access to the lamp socket.
Feb 27, 2009 | 2005 Chrysler Pacifica
"Popping" out the headlight module
see video by BOLID dated November 2008
Jan 11, 2009 | 2004 Chrysler Pacifica
Clean out carbon on 2004 Chysler Pacifica
Spray with tb cleaner and scrub with tooth brush respray.Needs to be done every 6 months on Pacifica
Jul 20, 2008 | 2004 Chrysler Pacifica
Street Glow Streetglow Streetglow H894 Headlight Replacement Bulbs Logo
87 people viewed this question
Top Street Glow Car Audio & Video Experts
xxxxxx xxx
Are you a Street Glow Car Audio and Video Expert? Answer questions, earn points and help others
