Question about Nordic Track NordicTrack Treadmill, A2550
Model c2270 treadmill( Nordic) has an error code FF and will not
All power seems to be good. when turned on the display tests good then FF comes up and nothing else happens.
5 Suggested Answers
  • 95 Answers
SOURCE: Nordic track c2255 console displays FF and will
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
Posted on Aug 01, 2009
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
Posted on May 20, 2010
I have a Sauter oven. When I try tuning it on nothing happens. No light,no fan,no heat.The clock display seems OK.I tried pressing the menu button several times.Nothing helps.What can be the solution?
I should suspect the fuse or circuit breaker that is supposed to power the oven if turned off.
It could be nothing more than a power surge from a lightning strike somewhere.
Find the electric box and check it out.
If the fuse or circuit breakers panel is good, remove the oven and check for current at the wiring that goes from the oven to the fuse/circuit breaker box.
If all that tests good, you have a problem with the oven control.
It may be "toasted". (No good)
God bless your efforts.
Sep 08, 2016 | Ovens
What should i do with my samsung n150 plus since it has no display on screen when i turn it on and only the led light for the on/off stays after turning on? Please help me.
Have you tried connecting it to an external monitor via the VGA port? It could be that the LCD panel has died. If this happened after coming out of sleep mode or hybernation I suggest pulling the battery, disconnecting the AC adapter and, with no power at all, hold the Power Switch down for a full 30 seconds for a complete power drain. Then reconnect the AC Adapter and replace the battery and test.
It's worked for me in the past - it just might work here.
Good luck,
TIH
Mar 09, 2015 | Samsung N150 Plus 101inch netbook
Acer aspire 5738 When i turn it on it displays a black screen then makes a 1 long beep and 2 short beeps But does the whole thing just once
Hello Klyera, Hi, A part of the laptop is either defective or shorted, you need to do the ff. this needs disassembling. hope your good at this. watch youtube video of disassembling laptops..
remove battery, charger
remove the keyboard, then power test the laptop..
remove the harddrive then power on test.
replace the memory card then power test
remove wifi card then power test.
I got a response when i disconnected the keyboard. hope this may help.
Jan 27, 2014 | Computers & Internet
The console not powering up
please see if your c.breaker is o.k 2) adjust the REED switch, clean it and tight the connector.see the diagram attached. 3) clean the ribbon cable inside the display board and tight 4) see if the power is coming to the display board.5) test the fuse.
Nov 14, 2013 | Nordic Track Nordictrack Audio Rider U 300...
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
The display reads ff and wont start
The 'ff' displayed is an error code. It means the display needs to be replaced.
To get the display replaced contact NordicTrack's customer service.
Their customer service info can be found here http://www.nordictrack.com/webapp/wcs/stores/servlet/Help_-1_10301_12401.
Mar 06, 2011 | Nordic Track NordicTrack Elite 7500...
Hi, I have an Acer Aspire 5610z and, when I turned on the Acer Logo nor bios post shows up. The entire display remains dark. If i press F8 or scape, nothing happens and no bio sound but, power light comes...
Dear User,
Remove the battery and connect the adapter and check if display comes otherwise the issue seems to be with system board.
Regards,
Tech_Comp
Feb 23, 2011 | Acer Computers & Internet
Nordic Track NordicTrack Treadmill, A2550 Logo
477 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
