Question about Kenmore 98702 Stacked Washer/Dryer
Screw stuck in washer bottom
I have a model #41794702300 stackable Kenmore washer/dryer. A screw from someone's pocket has fallen into one of the holes at the bottom of the washer tub. It fell in with the head sticking about 1/2 inch out of the hole. However, now that we've fiddled with it for two days, the head has come off. The tub will not rotate; so I'm guessing the other end of the screw is stuck in a belt or something. How can we access the underneath side of the tub to remove the screw?
  • 15,935 Answers
It appears you'll need to remove the tub in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
We have the kenmore stackable washer and dryer the water won't drain my husband thinks something is stuck in the pump Any ideas?
On the bottom front of the washer there are 2 screws.
Remove these screws and insert a screwdriver in the space where the front panel meets the washer top and push down on the screwwdriver. The locking tabs will come down with the front panel.
Pull the panel off and set it aside.
When you are through with the repair, tilt the machine back slightly and insert the panel tabs in the groove, place a screwdriver handle or something of similar thickness under the washer and front panel. Let it down on this and it will hold the panel up so that you can get the screws back in.
Apr 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Screws fall off panel inside dryer
Not sure why this keeps on happening, but I would suggest putting a tiny bit of LocTite on the screws and then replacing them. It really only takes a drop. Give them at least half a day to a day to cure. LocTite WILL STAIN anything it gets on, so be sure to let the stuff dry.
Hope this helps!
Feb 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
How to seperate a Kenmore dryer from the washer under it?
This is probably a model that has two access holes at the bottom front of the dryer -about 4-5" from each side- usually closed off with plastic discs. Just an inch up from the washing machine.  Pry out the plastic discs with a flat screwdriver and you should see a screw inside each of the two openings.  Remove the screws and you will be able to tip the dryer up and slide it back a few inches to detatch from the back.
Use two people to lift the dryer down as it is bulky but not too heavy.
Oct 11, 2007 | Dryers
Agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Apr 18, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
