Question about Moen Plumbing
Replacing Moen 1225 cartridge.
I have replaced many of these but this one in the shower refuses to turn right or left with the white plastic tool provided by moen to brake it loose. It will not pull out either. I assume the flat side washers are locked in place on the cartridge. I do not want to apply excessive force for fear of damaging the cartridge or faucet. I know there is a moen faucet puller available at Home Depot. Is this the answer and can I just twist the handle until it breaks loose. In the past when I applied force to remove the cartridge much of the flat side washers are left jammed in the hot and cold ports of the faucet. These are extremely hard to remove. Any suggestions. My plumber wants $125.00 for this repair which I hate to pay as the washer kits are free from Moen.com
  • jameslauer20 Feb 05, 2009
    I did try WD-40 but with the shower cartridge not being on an angle as the sinks are the WD-40 will not run down the cartridge. Thanks anyway
    New Friend:
  • 92 Answers
You will need a puller more then likely but what you can try is a little wd-40 lubricating spray
Posted on Feb 05, 2009
Remove stem of moen shower cartridge,
Moen makes a stem removal tool that angages the 2 ears on the outer portion of the stem. You can order from Moen:
http://www.moen.com/moen/cartridge-removal-tool-for-1200-or-1225-or-1222-cartridges/_/R-COMMERCIAL%3A104421
Or your local home center or hardware store should have one in stock if they carry Moen parts.
Jan 08, 2012 | Moen Plumbing
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
Jun 03, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
I have a single handle shower valve by Moen. Water is slowly leaking past the valve when shut off. I got the handle off but need to know how to further disassemble so I can replace whatever seal or o-ring...
there is a clip holding the cartridge in place. You need to remove that and then there is a little plastic throw away tool that comes with a new cartridge that you use to break the seals loose on the old cartridge....then you use a pair of channel locks to grab the stem and pull it out. The new cartridge should come with detailed instructions.
If it is a moentrol valve...the part number is 1225 and if it is a posi-temp it is a 1222. Moentrol you pull out to turn on and then left and right for temp adjustment. Posi-temp just turns to turn on and you turn from cold to hot to adjust through the temp range.
Dec 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Faucet is leaking. Can you tell me if this is a
yes it is a cartridge replacement,the cartridge is,should be all that you need to replace.you did not list what kind of faucet. so here is a few number's. some bath/shower valves' take#1225-(plastic) this is also use'd in some kitchen,lav, model's.two handle faucet's#1224,the "posi-temp"#1222 is a tub shower only,there are cartridge puller's available,and recomened them,one is made by moen,another by brass craft,i have pulled cartridge's with out,so it is up to you.hope this help's.
Nov 03, 2009 | Moen & Replacement Cartridge
Replacing Moen O kitchen faucet O ring
if it is dripping from the spout then there is a cartridge that needs replaced...1225 for the single handle type and 1224 for the 2 handle type. Moen does not use O-rings in their valves. If it leaking around the base of the spout there is an oring kit that you will need and you will have to pull the spout off to access them. Most Moen faucets use a 117 kit for the spout but there are some different ones.
Oct 19, 2009 | Moen & Replacement Cartridge
Moen fauset # 1225 Shower new cartridge and it still drips.
is it official moen 1225 ? generics can be of poor quality. turn off house water and remove cartridge. Small fingers? Put in valve and feel for debris or turn on whole house again for a few seconds to flush out valve. try another cartridge. Or try this first. take off handle and push in on stem. does drip stop. ? perhaps handle is not on right.
Apr 28, 2009 | Moen Plumbing
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
995 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
