Question about Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 2220i Error Code E000000-0000
When you power the machine on it comes up with E000000-0000
  • chevys12 May 11, 2010
    have black line on copies
    New Friend:
Canon printer ir 2200 error E000000-0000 my help
Posted on Apr 19, 2013
  • 22 Answers
The fixing assy is not reaching temp fast enough, lamp blown or thermal cutout.
Posted on Feb 06, 2009
2 Suggested Answers
  • 149 Answers
SOURCE: how do i fix my Canon imageRunner 2220i Error Code
The error code E-007 is a fixing film sensor fault, check for paper wrapped around the fixing film, foreign material blocking the film sensor, damage to the fixing film, fixing film sensor failure, or DC controller PCB failure.
you might be able to try and reset the code in service mode by hitting
the additional functions button 2&8 at the same time then the addit funct button again.. you might have to keep trying to reset the machine on and off till you are able to get in
once in service mode you hit the copier tab
then you goto the functions tab its in the middle of the screen across the top
then you will click on clear button
then the very first item on the next menu should be ERR
high light that and then click the ok button on the bottom of the screen a couple times then turn the copier on and off. hopefully the copier will come back up if it doen't then there is a problem with the fixing film and it will have to be checked out
Posted on Jun 22, 2010
Error code e000025-0100
overload with the motor or motor failure
1. Check conduction with FU2 on the DC Controller PCB
(UN09)
2. Check the harness/connector between the DC Controller
PCB (UN09/ J23) and PS06.
3. Replace the DC Controller PCB (UN09)
Check the harness toward the sensor
4. Check the Hopper Unit (Y)
5. Replace the Hopper Unit (Y).
Jun 13, 2015 | Canon imageRUNNER 2220i Grayscale Copier
Error e0000019 0000
go to the left hand side towards the back and you will see a door its about 6-7 inches long pull it open and remove the bottle and dump the waste toner
reinstall it and turn the machine on
Oct 23, 2013 | Canon imageRUNNER 2220i Grayscale Copier
Error code 0019
The error code E0019 means the waste toner bottle is full. To rest it you need to empty out the waste toner, it is easy to do.... On the left side of the copier toward the rear of the copier., there is one screw that holds on a panel. Turn the copier OFF first, remove the screw and the panel > the waste toner bottle slides out. VERY carefully pour the waste toner into a plastic garbage bag. You will see on the neck of the bottle two round spots.... Make sure you clean the inside & out side of the bottles neck. Reinstall the bottle and turn the power back ON and the code should rest.... Good Luck
Feb 27, 2013 | Canon imageRUNNER 2220i Grayscale Copier
Does it have a waste toner unit on the canon 2220i
yes, it is in left side panel on the bottom left corner .
Feb 15, 2011 | Canon imageRUNNER 2220i Grayscale Copier
How do i fix my Canon imageRunner 2220i Error Code E000007-0000
Jun 22, 2010 | Canon imageRUNNER 2220i Grayscale Copier
How do I log onto imagerunner 2220i?
if connected then web browser and copier IP address
Apr 05, 2010 | Canon imageRUNNER 2220i Grayscale Copier
Imagerunner 2220i - Scan-to-email Configuration
http to the machine and its under general settings can't think of exactly where off the top of my head
Nov 03, 2008 | Canon imageRUNNER 2220i Grayscale Copier
IR 2220i - change clock
Hello Debant2,
I believe on this model you go to additional functions (an asterisk looking button just to the left of the nine key pad) and this should give you a menu screen which will include a tab on the left that says timer settings. Press it and you should see where you can change the time. Take care. :-) .......SPINAL......
Apr 01, 2008 | Canon ImageRunner 2220I Copier
Canon imageRUNNER C3220 Color Copier Logo
2,903 people viewed this question
old marine
old marine
