Question about HP 2025 20.1" Flat Panel LCD Monitor
Everything is too bright
When i turn it on everything is too bright i can barly read anything. it started to happen after a power serge.
I have a similar issue. Opened up the unit and found that a module on the power board had a small bit of the insulation melted, meaning that that module is overheating. It's just a matter of time before that module shorts out and the screen goes blank. The power board needs replaced.
Posted on Feb 26, 2009
Nothing happens when the ignition switch is turned on
You should not change the wattage on bulbs as the increased load may wreak such havoc with your electrical system.
I would wonder that the main fuse would blow, do you have any power to anything?? Maybe you blew a lighting fuse.
If you find the solution please make a comment and post it.
May 09, 2014 | 2007 Harley Davidson FLSTN Softail Deluxe
2005 sts wont start or turn motor got new battery and try to start and kills the whole power
It sound like you have a bad ground, what will happen if this is the case is you put you key in the ignition and turn to run "not starting the engine" and everything is on and bright, when you try to turn the engine over it will click once "just when the key hits the start position" and everything will shut off lights and all. if you take the key out and do it again it will produce the same results.
Dec 10, 2013 | Cadillac STS Cars & Trucks
Car will not turn over but have lights
Hi, first thing you need to find out is if its a starter issue or power issue. Turn lights on and radio and anything else that is electrical in your car. Does everything stay on and bright? Does the car start clicking after a short time? If everything is good and your headlights are bright as they usually are, then you have a starter problem, maybe a connection problem from the battery or maybe it just went out(usually starters don't just go out without any warning) If the lights are dim or the car starts clicking after a few minutes having everything on you probably have a power issue. It's either alternator or battery. To test this get a jump start from somebody, when you get it started turn lights on and let run for a min. If it doesnt die shortly after that, disconnect the power side of the battery, if the vehicle continues to run then you have a bad battery if the vehicle dies it would be a bad alternator. Hope I could be of some assistance to you.
Jan 21, 2011 | 1994 Oldsmobile Cutlass Supreme
I cannot turn on my tv but it blinks for two times then turn off, it is happening without me touching anything. please help
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Nov 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Last night I finished hooking up my new Onkyo 7.1 HT-S5200 system. I used three HDMI cable to connect my TV, Blueray, and cable box. I upgrade the speaker wire to 16ga. The system is plugged into a Monster...
Turn everything off but the receiver. If it stays on turn another one on and see if it pops off if not continue. Most receivers have a pause start to prevent power surge. If it continues remove the protector and try the unit alone.
Oct 27, 2017 | Onkyo HT-S5100 Theater System
When HP laptop is pluged into power source screen goes dim
Right click on the battery icon in the taskbar, go to Power Options or something similiar. Change the plan settings for the power plan you're currently in. Check the brightness ratio for both battery and plugged in mode. This problem might come if you or someone had tinkered with the settings.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Dell 1900f monitor contrast/brightness problem
CLick start/run then type in dxdiag. Go to the display tab and click test dirext3d. There should be an 3d cube that comes up and spins around. After the cube leave cancel everything else and close dxdiag, Your problem should be solved for a pretty long time. If it happens again just follow the steps again.
Jun 11, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
The screen won't light up and when the screen slided up the screen display becomes too bright (white) that nothing can be read off it
My MDA loses its settings frequently as well. Go to Start, Settings, System, Backlight, and see what it looks like. Maybe the settings have changed.
Sep 06, 2008 | T-Mobile MDA
Video Flip-flops when shooting outdoor/Focused Bright Area OR Light
Hi Ramki
Camcorder can not be drop, maybe the brain damage and give the wrong figures to the camcorder and caused shot off and on.
I feel sorry about this bad situation, maybe if you have menu, see the trouble shoot, but I doubt it.
May 21, 2008 | JVC GR-D22U Camcorder
Sidekick 3 screen problem
This procedure usally will fix a white screen on a sidekick 3 or a sidekick ID.
Try this before you replace the LCD
Dec 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
HP 2025 20.1" Flat Panel LCD Monitor Logo
173 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
