Question about Zanussi ZWF1430W Front Load Washer
Zanuassi jet system frony loader has a bad smell
My zanussi jet system has a bad mouldy smell when i open the door. It now has transfered onto the clothes. i have tried using the vinagar solution but it hasn't worked. please help!!
    Scholar:
  • 99 Answers
Hi this is joyce
They sell a product called affresh it cost about $10.00 you put in the machine and run a cycle and this should take care of the smell. if this does not do it then run pure bleach in despenser and run cycle no clothes in washer. this will kill the mold. also never close the door completly on the machine because this holds moisture inside the machine, so leave a crack in door so the machine will dry out some. this should take care of the problem.
thanks
joyce
Posted on Feb 06, 2009
Our Zanussi FE1205 door seal is badly discoloured and mouldy. To clean it properly would be impossible without removal from the machine. Please advise how to remove it - or clean it in situ if that is...
Yes give it a good dose of mold remover fist then warm soapy water and a soft brush.Do this often to keep it clean leaving the door open if possible will help also.Good luck.
Apr 19, 2011 | Washing Machines
Foul smell comes from my zanussi jet system washing maching, so bad now that wahing smells of sewerage \r\nhelp please! i have a mountain of washing to do
Have u moved anything recently? the outlet hose must be above the sink waste outlet other wise water from the sink will go into machine
Jun 11, 2010 | Washing Machines
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
Mouldy smell coming from the machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
Frigidaire FTF530F
Please go to this website ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134609000een.pdf and look at the sectiopn pertaining to cleaning the dispenser drawer. In all probability, the dispenser is stuck and needs to be cleaned.
I hope that solved your dispenser issue.. As for the foul smell of the washer.. Front loaders are plagued with this problem and there is no known solution however there are a few things you can do to minimize and/or prevent that foul smell for a period of time.. After the last wash load, wipe down the door gasket thoroughly, If you do not have any small childern in the house.. leave the door open to allow the inside of the washer to air dry.. You can use a product sold at Home Depot ( and other places) called AFRESH and that will help for a while.. otherwise.. Front Loaders must maintain a leaktight sela to keep water from leaking but in so doing... it is also airtight.. herein lies the problem.. any standing water left over after a washer wil get stagnant and develop mold over time.. Hope this helped...
Aug 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
187 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
