Question about Hotpoint WMA46 Front Load Washer
Ashing machine not emptying
When on a wash cycle the machine keeps filling with water but not emptying causing it to flood kitchen and when it should be emptying it makes a clicking noise. but when it is put on the spin cycle it empties
  • 77 Answers
Check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Posted on Feb 05, 2009
Door will not open if machine not emptied immediately cycle ends
This is an anti-flood protection, since water would flood the kitchen if you could open the door. If the machine shuts down for some fault and leaves the drum with water in, then it is advisable to drain the drum down via the small hose at the front of the machine. Simply remove the plug and empty into a large container until the drum is empty. You can then start to work out why the cycle ceased prematurely.
Mar 08, 2015 | Miele Washing Machines
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Hotpoint Washing machine keeps flooding kitchen
For the age of it, you can either replace it or get it fixed. I would personally get a quote first for repair.
May 18, 2012 | Hotpoint Aquarius WT540 Front
Why wont my machine empty out..
The problem you are having is the pressure switch, also called the water level switch.Without a model # its hard to give any real direction for repair or any part #.
May 06, 2012 | Hotpoint Washing Machines
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
Hi, i've taken the top and sides off my Bosch dish washer sgs45e02gbas it has not been working. the problem is ....when you switch it on is there is a pumping/throbing noise but doesn't continue...
Hello Phillip,
The reason only the pump runs anytime its powered up is because the flood detector has detected water in the base of the dishwasher and until that water is gone only the pump will run.That flood detector is (when looking at it from the front) is in the left front corner,its a styrofoam disc with a rod in the center of it and has floated up activating the flood switch on the letf side wall where the water enters the tub (can be seen on the left side with side panel removed) if thier is no water in the base frame perhaps some foreign object has wedged itself under the sytrofoam disc holding it up. Until the water is out of the base frame only the pump will run as long as the flood switch is tripped.
Possible things that will make water be in the base frame are,
oversuds from too much detergent
a leak of any component or hose
a defective water level switch allowing it to overfill
GENE
Sep 06, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a bosch wfk 5730 washing machine has been very reliable but now continuously keeps taking water in to machine, at timer position "F", just before the final spinning cycle begins, till it...
Could be an iffy valve/ solenoid. One test is to see the empty machine slowly fills up with water, if you leave it for a few days. You can isolate teach valve by turning each feed off in turn. i t could be leaking all through the cycle. If it is flooding during the spin I'd check your pump at well. Hope this helps.
Sep 02, 2008 | Bosch Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Hotpoint WMA46 Front Load Washer Logo
474 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
