SOURCE: My Ridgid portable table saw is cutting out after
hmmm it sould be or it could be abad armature winding as well
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: motor will not start on my Ridgid table saw
Check the brushes and the commutator for wear and buildup between the insulated areas of the commutator..It should be clean and not full ofcopper residue.That will make the motor click only upon triggering the starter switch
Testimonial: "That sounds like good advice. I'll check it out. Thanks"
SOURCE: My ridgid table saw keep
My guess is that your breaker is too small. You need at least a 20amp breaker and the correct 12-2 wiring for the saw.
SOURCE: Ridgid TS3660 10 INCH TABLE SAW TH100085 MOTOR. I need replacement part for thermal cutoff switch
I have been fixing table saws, compressors and other tools with similar motors for several years and I have never been able to find anyone who sells just the thermal switch on these motors. I usually use one from another motor that's burned out if I need one. You'll have to find a repair center that has motors they could take one of these switches out of and sell/give to you. Otherwise, it's a new motor to get one.
Testimonial: "Thanks for your reply.....I have put my feelers out for a replacement."
