Question about Intel D945GCZ Motherboard
Heatsink for D945GCZ motherboard
I am looking for the large passive heatsink which sits ontop of CPU on the Intel D945GCZ motherboard. Can anybody help me with this, or suggest alternate cooling method? Thanks
  • 1 more comment
  • Anonymous Mar 04, 2009
    Thermal module for my Pentium D945 GCZ mother board is not available.The board is so far unused because of this problem.  I am from India, Kerala
  • nandkumartha Mar 04, 2009
    heatsink (thermal module) for D945 GCZ motherboard
  • slo_mo_05 May 12, 2009
    This is a BTX motherboard and the cpu is positioned 45 degrees of the mobo. Also there is BTX type l and BTX type ll. I think this is type l, but not sure.
  • 1,179 Answers
You can find great coooling solutions at places like or There are a large option of heatsinks & fans available for this board so it all depends on what you want to pay. Hope this helps.
Posted on Feb 05, 2009
Trying to find heatsink unit to be able to use the board
Hello here is the intel homepage:
Your mainboard is using the LGA 775 socket.
The heatsink fan looks like this:
The fan can still be bought in a computer store, online shop or a repair shop.
I will recommend to but a better fan, like the brand northq, because the standard fan is difficult to mount correctly on the mainboard.
Remember to add a bit of cooling paste on the cpu, before you mount the fan.
Good luck
Sep 17, 2013 | Intel D945GCZ Motherboard
CLip of motherboard felt off.
That would be for an AOpen AX4SPE-UN motherboard, because it has a Socket 478 processor socket.
I had it happen to an old mobo in the past, with a Socket 478 processor socket; and no clips.
I used a straight piece of coat hanger, and went from hole to hole, on one side.
Had a slight bend in the middle, and this bend went partially across one side of the finned Heatsink.
Small piece of coat hanger again, on the other side.
Cut to the right length, and with the correct bend, the two pieces of coat hanger, put even pressure down on the finned Heatsink.
Problem is they twisted. The pressure on the bent part against the Heatsink, made them want to spin up away, from the Heatsink.
So I added a piece of coat hanger on each side, to keep the side coat hanger pieces from twisting.
Hard to explain, and looked like something from Dr.Frankenstein's laboratory.
Worked though.
(Too much pressure, and it will break the plastic retention bracket on the motherboard.
Not even pressure on both sides, and Heatsink will not sit flat on Processor. This = No.
You just have to 'dial it in', (Coat hanger pieces), or use the correct part/s)
May 06, 2013 | AOpen AX4SPE-UN Motherboard
Needupgrading my cpu
On the top of every Intel processor is the sSpec Number, and the part number.
Intel Core2 Quad, that operates at a maximum frequency rate ('Speed'), of 2.66GigaHertz,.........hmmm,
Gateway Support indicates if the option is a Core2 Quad core, it will use Up To a 1333MegaHertz, Front Side Bus frequency rate, ('Speed'),
[1333MHz FSB]
That 'narrows' it down to about 6 different processors.
Starting with the Yorkfield-6M Core technology, based on the 45NanoMeter architecture. (45nm),
1) Core2 Quad Q8400
2) Core2 Quad Q8400S
3) Core2 Quad Q9400
4) Core2 Quad Q9400S
Then on to the Yorkfield Core technology, based on the 45nm architecture,
5) Core2 Quad Q9450
6) Core2 Quad Q9450S
The maximum frequency rate of 2.66GHz, is actually a low estimate. It is a little higher, and rounded off to 2.67GHz.
BIOS Setup might state 2.66GHz, but a better program like CPU-Z, IMHO; will state 2.67GHz. A more realistic figure.
Does it REALLY matter? Yes, and No.
This way when you get into a conversation, with fellow minded computer geeks, you will stand out as one who knows; what hardware components he/she is using.
Also helps you determine what voltage range is being used.
What Instruction Sets are being used.
What technology is being used, and use it to know if the upgrade CPU will indeed work.
Also whether a BIOS upgrade is needed.
I'm guessing it is the Intel Core2 Quad Q8400.
I cheated, lol!,
Intel Core2 Quad Extreme at a maximum frequency rate of 2.93GHz?
That would be the Intel Core2 Quad Extreme QX6300,
Based on the Kentsfield XE technology, and 65nm architecture.
Uses a 1066MHz FSB.
Motherboard chipset is the Intel G43,
(Scroll down. Is not in 'alphabetical order'. It is past the P45, and G41 )
Yep. Should work.
Makes me wonder though, about how you addressed the Thermal Paste; situation.
The old Thermal Paste MUST be THOROUGHLY cleaned off, and fresh, new Thermal Paste PROPERLY applied.
CANNOT reuse old Thermal Paste.
CANNOT reuse a Thermal Pad, IF used.
Do I also assume the inside of the computer case is spotlessly clean, to include the Heatsink sitting on the CPU; and the cooling fan for it?
Heatsink was sit on CPU flat?
Cannot be even a little tilted.
For this reason I remove the motherboard, and install Heatsink.
Then I can hold the motherboard at eye level, and look across.
If a tiny crack of light shows on one side edge, of the Heatsink; then the Heatsink is NOT sitting flat.
This = No.
Four screws with springs on them, hold the Heatsink to CPU, Joe?
Yes. I know. This is so you cannot over-tighten the Heatsink to CPU.
You CAN however keep tightening, until the motherboard breaks, though. (Jus sayin')
However, if the screws are not tightened in a crisscross fashion, and tightened in incremental stages; the Heatsink may not be sitting flat.
Will await reply before going further. Post back in a Comment.
Note* Using capital letters for an entire word, is not 'shouting' from me.
It is to emphasize.
Mar 24, 2013 | Gateway DX482203 (PTGA002009) PC Desktop
Aver AX1700 high cpu temp
apply some quality thermal paste (silver grease) between cpu and heatsink to maximaze the hat transfer between those 2 elements
Mar 13, 2012 | INTEL - BLKD945GRWLK Motherboard
My pc mobo is intel 915gav. processor is P4 pinless running with 1 gb 400 bus ram..after a new installation of win xp i worked hours continously..but in in next morning when i turn on pc after running
There will be a thermally conductive paste [Heat sink compount], a white tooth paste like substance, must be applied between the heatsink and the CPU. It is a must. If you have replaced, or unlocked the heat sink metal, and haven't applied this thermally conductive paste, proper heat transfer from CPU and the metal heatsink will take place, and the CPU will overheat, and finally go out.
Music videos are large files, which apply a great load to CPU, as processing video is a great task for CPU. Temperature must be below 40 degree centegreade, at any instant.
Just unlock the heatsink lock, take out the CPU heat sink out, and apply some heatsink compound [silicon grease] and retry. If you hear a beep sound after 3 seconds or so, after swithch ON the system, you have won. OK.
Feb 22, 2012 | Intel D915GAV Motherboard
I don't know technical terms but there is a 4screw x that holds the sink to the mother board just to the right of the x is a small square over a chip is the square super to have a pad on it or no pad and...
Let me see if I can decipher what you have stated killa_klowns, and offer a solution.
1) The Processor has a Heatsink on it, or a Heatsink/Fan combo. Depends on what the computer manufacturer designer wanted to implement.
{Some computers have a Heatsink/Fan combo sitting on the Processor.
Other computers just have a Heatsink sitting on the Processor, and air is provided by a Front computer case fan pushing air through a plastic cover onto the Heatsink}
Typical design for a Heatsink/Fan combo (Stock design. LGA 775 processor socket. Also, not a gamer type of rig),
Photos showing typical Intel Pentium 4 processors. Shows the top of the Processor's case that the Heatsink sits on,
Where the headings state > Specifications - Pictures (5) - CPU ID (1) - Comments (15),
click on Pictures (5)
Thermal Paste should be used on the top of a Processor's case.
If there is a Thermal Pad, take it off, and fly it at the cat.
They're JUNK!
[ Always Thoroughly clean the top of a Processor's case, and the bottom of the Heatsink, before applying fresh new Thermal Paste. Same thing for every chipset.
> Observe Anti-Static Precautions A Processor is the most susceptible hardware component to Static shock.
Use a plastic scraper to clean the top of the Processor's case, and the bottom of the Heatsink.
I use an old credit card.
Then use Q-tips dipped in Isopropyl Alcohol (Rubbing alcohol) to clean the top of the Processor's case, and the bottom of the Heatsink.
May take several Q-tips dipped in alcohol. Usually a gooey mess.
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a Well ventilated area with No sparks or flames present ]
The next chipset in line to use a Heatsink is a Northbridge chipset.
Termed Northbridge, for one, because in relation to how it is sitting on the motherboard, it is to the North of the motherboard.
On the motherboard the Northridge chip sits below the Processor.
The Northbridge chip may, or may Not have clips which hold the Heatsink on.
When no clips are used, > Thermal Glue is used to hold the Heatsink on.
{The motherboard chipset is the Northbridge chip, and the Southbridge chip.
Note* This info does Not apply to motherboards that support the Intel Core i3, i5, i7, or i9 processors}
The Super I/O chipset does Not use a heatsink.
Motherboard diagram, }
Tell me what the motherboard manufacturer name, and Model Number is, and I can give you more detailed info about that motherboard.
Dec 04, 2010 | Sunon (16-02-006) Fan Kit
Need direct link to heatsink fan for Intel D945GCZ motherboard. What size, type, pins etc.?
this is a site about the specs on the board. it will tell you the socket type that is required for it. and what other specs you might want. CLICK HERE
Sep 30, 2009 | Intel D945GCZ Motherboard
My motherboard is producing too heat
Take you Haetsink ontop of the CPU, make sure it's clean, get some thermal grease to put ontop of the CPU, and underneath the Heatsink, that should bring your temp down, also make sure that CPU fan is running fine whenswitched on,
Good luck
Jun 01, 2009 | ASUS M2N-MX Motherboard
Overclocking on this board with an E2180?
When the CPU overheats it shuts down especially if you overclock it.
Did you put any heatsink compound between the CPU and the heatsink (this aids heat transfer from the CPU to the heatsink/fan)?
Your BIOS may have a setting that can adjust the CPU fan speed/temperature.
You can install additional fan/s in the case to draw more air into the computer case.
To further cool the CPU, you might have to install a better and more efficient cooling heatsink/device/fan on the CPU.
Feb 10, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mar 24, 2008 | Computers & Internet
Intel D945GCZ Motherboard Logo
293 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
