Question about Whirlpool Calypso GVW9959K Top Load Washer
L5 flashing on my calypso washer
When i go to start my washer it flashes L5 and won't start. How do I fix this?
  • jamanning11 Feb 05, 2009
    I tried to look at the washer to figure out where the lid switch even was and I'm not sure where it's located.
  • DellaL Apr 08, 2009
    My Calypso washing machine says S5 and will not start. Did anyone find a solution for this?
  • 1,029 Answers
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Posted on Feb 05, 2009
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Feb 05, 2009
    hope this helps pls do let me know.thanks and Godbless
    Starnley Johnwells Feb 06, 2009
    LS Lid Switch Error The control should flash this error code if it
    cannot detect the lid switch opening and closing properly. This error
    code may also be used if there is a disagreement between the motor and
    machine controllers on the stat if the lid switch. The control should
    not allow the unit to run in this condition.
    This code will also appear if the user presses the START key while the lid is open.
    Open the lid or press STOP/CANCEL to clear the display.
    To gain access to the lid switch on this washer, you’ll need to remove the washer cabinet shroud.
    With the washer cabinet removed, you have easy access to the lid switch. If the actuating lever looks ok, then you should use your ohm meter to check the continuity
    of the lid switch. Many times, if the switch is bad, it will no longer
    make a clicking sound when you actuate it. Your lid switch can be
    replaced using one of the kits below, most likely the older style. But
    you can easily confirm this by feasting your Vulcan squinties on your
    washer’s lid switch.
Its saying Ls
Posted on Apr 19, 2009
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
Aug 01, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
I have a whirlpool calypso. What does L5 men. It won't do anything!!! Help!
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Sep 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is L5 code on whirlpool calypso model #GVW9959KQ0?
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stops working and the light flashes L5
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Out of balance washer code l5
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
After starting the washer I get a L5 flashing display and my washer powers off. What can I do?
May 03, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer wont do anything and keeps flashing L5
The control should flash this error code if the following conditions occur: ? The control cannot detect the lid switch opening and closing properly. ? There is a disagreement between the motor and machine controllers on the state of the lid switch (the control should not allow the unit to run in this condition). ? The user presses the START key while the lid is open. ? The user presses the START key without opening thelid between cycles.  Open the lid or press STOP/CANCEL to clear the display.
Apr 28, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
L S or L5 error code on Calypso top load washer (Color - grey)
LS Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
1,380 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
