Question about Miele Novotronic Premier 500 Front Load Washer
Washing machine w827 drum fills when the machine is switched off
The machine works ok, but even when the machine is switched off the drum fills with water over a couple of hours.
  • sharryan May 09, 2009
    drum fillinfg with water even when the machine id powered off
    President:
  • 2,976 Answers
Before you replace the valve, try to back flush it. It may allow you to run water through it from both directions and clear the obstruction. That wil save you the cost of a new valve. Also, get some inlet hose filter screens. They go into the supply hoses, with the narrow pointed end toward the water supply.
Posted on Feb 05, 2009
  • 135 Answers
You have a bad water inlet valve. There is probably silt in it and it is stuck partially open. Replace the valve and you'll be back in business. Hope this helps!
Hotpoint aquarius washing machine
If you have pressed start or pulled out the knob of the cycle unit and nothing happens I would be checking the operation of the water inlet solenoid . If it is not getting power or it is not opening the valve to allow filling to commence there will be no further action of the machine until the tub is filled to the desired level.
Aug 17, 2013 | Washing Machines
Washing machine will not stop filling up with water
Is the machine siphoning off water as it fills? If it is check the height of the drain hose and make sure it is above the height of the normal level of water that would be in te drum when washing, if the hose is to low the drum will siphon off the water on its own and continue to fill. If the machine is not siphoning off water while filling then you may have a blocked pressure hose or the pressure hose bottle may be blocked not allowing the pressure switch to activate. there may even be a small hole in the pressure switch hose. Check the thin pressure hose that goes from the bottom of the drum to the pressure switch.
Dec 27, 2012 | Indesit W 123 Front Load Washer
Washer fills and empties but won't wash or spin
hello,
If the motor is spinning very rapidly when it should just be tumbling then it sounds like the tacho has gone or come loose on the motor.It may well need a new motor or there could even be a fault with the main programmer
Apr 17, 2010 | Tricity Bendix AW1000W Front Load Washer
Machine not spinning out comes up error7 it is a haier hns 1460 tve model , pump is filling up and emptying drum ok , took back cover off belt and spider both fine drum turns if you turn belt what could be...
Check lid switch.
If you have wash action from then the motor is most likely O.K.
If your lid switch is faulty, the machine stops before the spin cycle.
Ash
Oct 21, 2009 | Haier Washing Machines
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Washing machine fills with water ,empties,ok but will not turn drum
If you can get to the wires on your lid or door switch unhook the wires from the door switch and with the ends touching wrap electrical tape around them tight and try the washer again. if it works its a faulty switch
Aug 26, 2009 | Washing Machines
Miele Washing Machine - Novotronic W827
Give the door a firm push shut (even if it appears shut already). There is a safety mechanism that stops the door opening when drum is turning and it gets its knickers in a twist sometimes. Happened to me twice in the last 5 years and can never remember how to fix so end up ringing Miele support who are always helpful. Next time I'll look here first!
Oct 31, 2007 | Washing Machines
Miele Novotronic Premier 500 Front Load Washer Logo
290 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
