Question about Necchi 3537 Mechanical Sewing Machine
Thread getting knotted
I've tried adjusting the tensions but the thread is becoming a big knot when i sew . any thoughts or help??
    Problem Solver:
  • 10 Answers
My machine does the same thing. Unplug the machine, and open the bobbin case. I would bet that you have "orphan" thread still sitting in the bobbin area that is bunching up the new thread.
Your bobbin area should be opened, cleaned and well oiled to ensure that no loose threads are sitting in there waiting to create "tension" with you and your machine.
I have found that when I have not cleaned out the bobbin area, there are loose threads, lint and fibers left behind from other projects that I have been working on.
Get a new can of compressed air, and blow out the lint, and left behind stuff, and see if that doesn't fix your problem. If it's been a while since you have taken it in for a "tune up", it should be done if you use your machine often. Happy Sewing!
Posted on Feb 05, 2009
My singer 6136 bobbin keeps knotting up
Are you getting knots under the fabric when you sew? If so, that is bird nesting (thread nesting) and is commonly a top thread issue. Most often the thread is not seated fully in the tension disk or the top tension setting is off.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the tension at the midway point and then tweak it so the top and bobbin threads meet in the middle of the fabric.
Jul 20, 2017 | Singer Sewing Machines
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
How to set the tension
The carrier and bobbin are removed. Place the thread in the carrier with the thread dispensing counterclockwise. Place the thread between the metal pieces (tension). let the carrier hang from your finger and bob it slightly. It should extend one inch. If it doesn't then you can adjust it by turning the small screw slightly until it does what I said. Now, replace this assembly. The top tension you can start at three. The sewing should be an even pull between the upper and lower thread. If the thread knot is in the center of the material it is right. If the knot is under the material then raise the upper tension. If the knot is on the upper material then you should lower the upper tension. The key is to start with the bobbin tension correct and adjust the upper tension until the knot is in the center of the fabric
Oct 26, 2014 | Sewing Machines
How adjust bottom tension on this as it keeps knotting up?
If your top thread is knotting up in bobbin area, your top thread is mis-threaded, possibly out of take-up lever or tension disks need cleaning/adjusting.
Sep 28, 2014 | Singer Sewing Machines
Bottom thread tangles and knots
usually a top-thread tension issue, try tightening up the top thread's tension, there is usually a disk or knob somewhere to adjust it.
Dec 10, 2013 | Sewing Machines
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
Sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Necchi 3537 Mechanical Sewing Machine Logo
89 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
