Small personal copier Canon PC-14
This is an older copier that was given to me with no manual. When I press the button for it to copy, "P" comes up in the instruction window.
  • 77 Answers
Check the paper in tray. if it is there reload it.check any jameed paper in the machine.
Posted on Feb 06, 2009
I waint to know how to inter sim 14 for toshiba photo copy m/c model e-studio 161
Hi Wahdain,
Its so simple enter the formula given below. First press the C button then press the exposure mode change button ( this is what you used to change the exposure from auto to manual or photo modes) then again C button, then again exposure mode change button then 1 and 4 then start button ( this is what you press to take a copy) Try this and put it right.
Best Regards,
Rakshita
Jul 07, 2011 | Toshiba e-Studio 161 Copier Copier
Pages copy all black
It sound like the scanner is not lighting. Open the cover and press green copy button. As the scanner moves it should produce a green light. If it does not then the halogen lamp will have to be replaced. Its part number is FH7-3381-000 for the 120v model and FH7-3380-000 for the 220/240v one. personally I would not bother as they are not worth repairing.
Apr 28, 2011 | Canon PC-921 Black and White Copier
Ink absorber
Manual Reset for Canon Pixma MPC190 Printers
  1. Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  3. Select 8 PRINTER TEST TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Mar 01, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How to change paper size from letter to legal
I dont have info on your PC-920 but almost all canon copiers use the additional function button to gain access to settings. Try selecting the additional function button on the operation panel, then use the - or + buttons to scroll thru your options. When you see Reg Paper Size press ok then use the - or + button to select 8 1/2 x 14 Legal paper then press ok. This is the steps to take on small canon copiers like the ir 1019 and 1023. Your copier is just about the same so this might work. If you have a user hand book that info should be in there. Good Luck.
May 14, 2010 | Canon PC-920 Black and White Copier
I turn my xc1044 copier on and get a H3 code and machine will do nothing
You can try resetting the code. If it comes back then the machine will need service. The H3 code is a fuser code which is the part that gets hot right before the paper exits the machine.
Press the C key then the far left key then the C key then the far left key. So C,far left,C,far left
These 4 keys must be pressed within 4 seconds. If done correctly your display will go blank.
If so then key in 14 as if your were going to run 14 copies then press the print button.
This will reset the code, at least temporarily. The H codes sometimes pop up when there is no issue with the copier.
If it comes back you will need a repair person.
Good Luck and Thank You for using Fixya.
Mar 11, 2010 | Office Equipment & Supplies
I have a canon photocopier IR3035 I want to check how many copies it has done it then. How can I get that information in that copier.
Press the counter check button on the control panel, located just above the stop button, right hand side. (page 1-14 in reference guide)
Oct 13, 2009 | Canon Office Equipment & Supplies
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
Don't know how to make a copy
yes you are suppoused to put the original in the platten-glass an dthe push the green button that means Start copying. and yeah the copier must have paper on the right side.
Jan 24, 2009 | Canon PC-400 Color Copier
Trouble code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
May 06, 2008 | Sharp AR-160 Copier
Actually a Canon PC-65, problem follow-up
canon older model PC_6RE problem: the third copy and byond, streeks appear on the left side, progreesivly get worse on each additional copy, a wait of about 2,hours, then the 1st copy is clear again, any solution for this?
Jan 03, 2008 | Canon C130F Black and White Copier
k24674
