Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
I want to update my display adapter driver
Intel(R)28945G Express chipest family ho to update and where i find thist update
  • 38 Answers
Http://www.intel.com/support/chipsets/sb/CS-022034.htm
This is the intel site for your graphics card family. Please try installing the 945 driver on the site, it should work for you. (should be the middle one)
Posted on Feb 05, 2009
    President:
  • 1,179 Answers
You should be able to update all drivers/software for your board at the Intel website under the support section. All you will need to do is lookup your specific board model # and it will give you a list of all bios & driver files available for it. Hope this helps & please rate this solution fixya. Thanks.
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
Mar 19, 2013 | AU Optronics Acer Extensa 5620-4801...
Just now i formatted my laptop and installed windowsXP. For that i need all kinds of drivers to installed and i dont know were to find this.My laptop model is A135-S4527
I bought a Toshiba A135-S4527 with Windows Vista Premium installed on it. I quickly decided to downgrade to XP Pro. It took me days of searching to locate all the drivers since Toshiba does not provide XP drivers for this laptop. Installing all the updates from the Windows Update site did a lot of the drivers for me. HOWEVER, Windows Update will misdiagnose the display adapter. It will try to install a driver for the Intel 945GM but it must be some generic 945GM driver, because it will not give you full functionality (e.g., multiple display outputs, etc). Use the method I describe below to get the correct 945GM driver for this display adapter.
Hardware and drivers needed to run Win XP Pro on Toshiba Satellite A135-S4527
Run "infinst_autol.exe". This is an Intel Chipset Software Installation Utility (now called Intel Chipset Device Software I think). It will identify and load the proper driver files (.inf) for various things. I did this at the end last time, but if done near the beginning, it might take care of things like display adapter, etc. Check Intel's site for the most updated one. Go to http://www.intel.com/support/chipsets/inf/
Display adapter is Mobile Intel 945GM Express Chipset Family
Driver was named win2k_xp14182.exe. I downloaded it initially from
http://downloadcenter.intel.com/deta...1&dwnldid=9683
&agr=n&lang=eng&prdmap=2301
Mouse is Synaptics PS/2 Port Touchpad
Driver file was called XP_2K.8.3.4.zip. Can be downloaded from the Synaptics website.
Wireless adapter is Atheros AR5006EG
Driver can be gotten from Windows Update (or maybe the Win Vista CD too)
Ethernet adapter is Realtek RTL8139/810x Family Fast Ethernet NIC
Modem is Toshiba Software modem
Driver can be gotten from Win Vista CD.
During XP installation, drivers were automatically loaded for:
- multimedia card reader
- firewire port (IEEE 1394)
- DVD/CD drive
I have this for Mobile Intel 945GM Express drivers:
http://downloadcenter.intel.com/Prod...ProductID=2301
Using Atheros AR5xxx 5.3.0.35 for wireless drivers:
http://www.opendrivers.com/downloado...php?href=47456
Realtek High Definition Audio 5.10.0.5436
http://drivers.softpedia.com/get/SOU...ver-R170.shtml
SmartCard 2.0.0.6
Haven't looked
Intel Chipset 8.3.0.1013
http://downloadcenter.intel.com/Deta...13499&lang=eng
Realtek RTL8139/810x Fast Ethernet NIC
http://www.versiontracker.com/dyn/moreinfo/win/54582
I used a program called "driver genius" and it located the driver versions needed for this laptop.
Dec 15, 2010 | Toshiba Satellite A135-S4527 Notebook
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
I have Intel(R) 82945G Express Chipset Family
Mmmm,doesn't sound good. If it's dropping the driver then works intermittently,there's 3 possibilities. One go to the intel site & download the latest driver for that chipset or check the hard drive with a program like tuff test pro(commercial diagnostic tool,google it),if all checks out the board has an issue. I think you get where this is going from there.
Jul 15, 2009 | Intel 845GE Motherboard
Need a driver but can't install
It might be windows problem try to reinstall your windows & after do the needful work e.g. reload the drivers.
If the problem persist connect to the internet the try to update the driver.
May 29, 2009 | Computers & Internet
VGA driver for toshiba A135-S4527
- DVD/CD drive
I hope this gets your laptop up and running.
Please rate my solution,
Eric
Jan 22, 2009 | Computers & Internet
Bt Driver ,and Mobile Intel(R) 956 Express Chipest Family
I do not have your problem but did some quick reading.
If you have the XP install disk with the SP2 on it, try reinstalling. You will not have to delete all you old files, you will be given the option to repair or do a new install over the old one. I personally have found the repair option to be a waste of time.
Jan 21, 2009 | Dell Ethernet Card Network Adapter
I NEED DRIVER UPDATES BUT I DONT HAVE A REG.KEY....
hiiii ther
how r u ??
go to acer.com u will findall the vista update to ur driver
but 1st u need to check if ur machine is compatible with vista if it is
u will find all the update on the acer.com under ur laptop model
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 22, 2008 | Acer Aspire 3680 Laptop
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
752 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
