Question about Compaq Armada M700 Notebook
Intel pro nic no i/o resources
I have a compaq armada m700 P3 850mhz, win xp pro sp2, 512mb ram, 6gb hdd. my problem is that the intel pro/100+ minipci cant get an i/o resources, it is recogrenized since it is in the device manager under network tab, but it has an exclamation sign so i downloaded from intel the latest driver and still no i/o resources to work on, pppppplease help, tnx
  • Joey Serrano Feb 06, 2009
    i have tried, uninstalling / reinstalling the latest driver for intel pro/100+minipci, reseated / unseated the card, i have 2 of the same card both working fine from my friends m700, if i pguin the rj45 to the card the green led is lighted and the orange one is blinking suggesting the card is trying to communicate, but if go to the device manager tab under network i see an exclamation point with the card, i tried to check thru property tab and it says device cant work and is not using any resources, what to do next, again help
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Have you tried doing a driver roll back?
  • 139 Answers
Its simple try this card on some other if u get the same error replace the card
Posted on Feb 05, 2009
I just bought a Compaq Armada 7400 (made in 1998) and it has a WIN 2000 on 10 GB HDD How do I remove the HDD from the caddy to install WIN XP PRO on a 100 GB HDD Thank you
Here is the drive removal instructions. Make sure you have enough memory for XP and that Compaq has drivers for your model.
http://www.cmsproducts.com/pdf/driveremoval/Compaq/Compaq%20Armada%207300%20-%207400.pdf
Mar 01, 2009 | Compaq Computers & Internet
Intel pro/100+minipci config
To get into the BIOS configuration, press the F10 function key as you power up your laptop.
Feb 01, 2009 | Compaq Armada M700 Notebook
Compaq D51S/P2 can somebody help me drives for this ?
Drivers for this model can be found below
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=97129&taskId=135&prodTypeId=12454&prodSeriesId=96300&lang=en&cc=us
Compaq Evo D510 Models with Intel 845G Chipset All D510's come with: Integrated Intel Extreme graphics Integrated Intel PRO/100 VM NIC Integrated Intel PRO/100 VE NIC (e-pc only) Integrated Intel Audio Model Key
Example: D5S/P1.5/20j/2/128c/vn
D51S
D510 Small Form Factor
D51C
D510 Convertible Minitower
D51U
D510 Ultra-Slim Desktop D51E
D510 e-pc P2.0
P4 2.0Ghz processor (c = Celeron) 20
20-GB hard drive K
XP Professional X
XP Home P
XP Pro/2K dual install 2
Win 2K 256
Memory amount
C
CD ROM
R CD-RW
N NIC
Jan 27, 2009 | Computers & Internet
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Installing a Seagate Dive into an Armada M700
Here at my shop I have run into this exact same problem on several P3 Compaq's and a few Toshiba's. I found that some of these machines, not all, but some, will not accept the 5400RPM drive, but will take the 4200RPM drive just fine. It's just weird because some that do are the exact same model, and I'm not real sure why it won't accept them. I've looked into it and the best that I can surmise is that 5400 is too fast for the reading system in the bios, or it's a power issue. Go with a 4200RPM drive and you shouldn't have any problem. You won't be able to tell any difference in the machine's performance between the two RPM speeds.
Aug 01, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Says ive used all my memory up but i havent
Armada M700 Specs
Full sytem requirements of FL Studio:
  • Pentium III or Athlon XP (any processor supporting SSE instructions) or Intel Mac with Bootcamp (running XP or Vista) or running Parallels
  • Windows 2000/XP/2003/Vista (32 & 64 bit)
  • 256MB ram
  • 200MB free harddisk space
  • Windows-compatible soundcard with DirectSound drivers. ASIO drivers are required for audio recording (FL installer comes with generic Asio4All drivers)
If your system meets the minimum system requirements, it'll be your actual system resources (memory, CPU, ...) that could impose limits on your FL Studio projects.
The faster your CPU the more channels you will be able to run simultaneously and/or the more effects you will be able to use. The more memory you have the larger the samples you will be able to load.
May 15, 2008 | Compaq Armada M700 Notebook
Code 10 error over my network adapter in device manager
You need to download and install the proper drivers from Compaq (now HP). Go to http://www.compaq.com and do the following:
Click "Get Support" at the top.
Enter "armada m700" in the "Enter a product number" box.
Click the little submit button that looks like ">>".
Click "Download drivers and software".
Click one of the "Windows XP" links. Doesn't matter which one.
Scroll down and click the "Download" buttons that correspond to each driver you want to download.
Install the drivers you downloaded.
Feb 02, 2008 | Compaq Armada M700 Notebook
Code10 over my Network Adapter
go to the intel website and troll for the driver for that card.
make sure in adminstrator tools, services that windows zero configuration is 'started'
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
