Question about Canon PIXMA MX310 All-In-One Printer
Printer won't turn on
I had a paper jam last night. Cleared it.  Now printer won't turn on.  I have turned off everything, reconnected.  Still machine won't turn on.
  • pmcguane Feb 05, 2009
    Thanks for the suggestions but neither worked.  Any other great ideas??
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    There should be a reset button either on the front or on the back of the printer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
Try unplug the printer for at least 15 mimutes.
This may reset your printer.
Posted on Feb 05, 2009
Paper jam error message
On mine you have to take the duplexer out of the back of the machine to convince it there's no jam. On the 4350 you press 2 buttons on the sides of the duplexer and it slides out. Look at it, scratch your head and then push it back in. Magically the paper jam is cleared.
Apr 05, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
HP 3030 error message paper jam - clear papaer path. There is no paper in the machine. I have cleared and cleaned the machine, turned it off, waited 30 secondsand turnedit back on and still get the error...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 29, 2011 | HP LaserJet 3030 All-In-One Printer
Phantom Paper Jam
There may be a problem with the fuser unit. First check all the doors and drawers for paper jams, including removing the toner cartridge and looking inside. Leave the cartridge out, turn off your machine, unplug for 1 minute, then turn back on. Close door without the cartridge inside. Machine should tell you to insert cartridge. Put it back in, and see what it does. If a simple reset like i have described does not solve the problem, there may be a small piece of torn paper somewhere, or a sensor may be broken or dirty. Please reply with the results!
May 07, 2009 | IBM Infoprint 32 Laser Printer
Cleared paper jam &printer will not reset
I had to turn off the printer & disconnect the power cord. I also had some material that was backed up on hold from the night before that was preventing the current material from being printed & I had to go in & cancel the documents to be printed before the printer would function.
Jan 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I cleared the paper jam but printer still wants paper jam cleared.
Turn the printer off, unplug it, wait 10 seconds, plug it back it, and turn it back on. If it still says there's a paper jam, there is something interfering with it. Turn it off again, pull everything out that you are meant to, poke around, take anything you see that doesn't belong out, put everything back in the right place, and turn it back on. If you still have a problem, you should contact the manufacturer.
Dec 06, 2008 | HP Deskjet 6940 InkJet Printer
I cleared paper jam, printer won't respond, still have error messages
turn it completely off..let it sit for the length of a cup of coffee..try it again..
Oct 13, 2008 | Lexmark E450dn Laser Printer
Error - carriage jam message
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Mar 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Printer error code
E-3 indicates a paper jam. Turn the power off. Try removing the paper and lift up the scanner top to see if there is any paper, debris, or foriegn object in there. Gently remove anything you find. Turn the power back on and press the start (black or copy button) and hopefully you will have cleared the problem. If not, you can try to reset the machine by turning it off, unplug it from the power source and remove the USB cable if it is connected to a computer. Plug it back in and turn the power back on. If this still does not clear your error, it may need to be serviced. I had this same problem last night. I did not find any paper jammed, but there was a small black twisty tie stuck in under the roller - it took me several tries and over two hours last night and another 2 hours today to discover the problem. It works fine now. However, before my second try at fixing it today, I had given up on it and purchased another printer online. Now what will I do with two? Hope this helps you. You can also try calling Canon tech support at 1-800-828-4040.
Nov 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Paper comes out plain
WAs the jam in drum?, check if carona on drum is intact (under the little slidy cleaning tab)
Nov 07, 2007 | Brother MFC-8440 All-In-One Laser Printer
Paper jam cleared - but still won't work
turn off the printer for a while then back on again, if it still refuse to print, try printing a test page.
Feb 13, 2007 | Canon LBP 800 Laser Printer
Canon PIXMA MX310 All-In-One Printer Logo
436 people viewed this question
old marine
old marine
