Question about Cambridge Soundworks TVWorks 250 Speaker
Tv sound only from right side
Sony trinitron- I have sound coming from the right side. How do I connect the left side sound? Thanks
    President:
  • 2,976 Answers
If you have the wires connected properly for stereo sound, go into the setup for the TV and set it for stereo speakers.
Posted on Feb 05, 2009
SOny FD TRINITRON WEGA XBRKV-40XBR800....IT STARTS SOMETIMES AND THEN SHUTS OFF ALL THE SUDDEN. NOW IT WONT TURN ON BUT FOR A FEW SECONDS AND SHOWS RED LINES ON THE SCREEN AND THEN SHUTS OFF. LIGHT ON...
Hello
Your tv has problems in power regulator side, which is in the printed circuit board of the telivision. Sometimes it may due to some socket contact problems. You just contact a technician., while you cannot do it right by yourself.
Oct 16, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Picture shifted to left 1/3 and left portion shows on right side 32" sony trinitron (not flat screen)
Probably caused by a failure of certain bipolar electrolytic capacitor(s) in the area of the high voltage circuit.
May 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron model kv-a2921b. The TV
HELLO MIKE
I don't think your TV is totalled! It's more than possible that a speaker connection on the main board has come adrift and just needs pushing back in. Check connections on the speakers themselves and when you trace back the cables there will one or two push in connectors.
It may be a good idea to get the speaker connection plugs checked and resoldered. It is also possible that the fall could have jolted the audio IC and this should be checked for dry joints or cracked print on the board too.
Hope this helps (:-)
Oct 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Help tv no sound
Hi There,
Well I hate to be the bearer of bad news but it sounds like your sound module or IC needs replacement. Hooking the surround sound won't help because you have no Audio Output. I hope this helps and thank you for using FixYa!
Mar 28, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
No image onscreen Sony Trinitron model# KV-27S25
Hi
try to connect the Antenna then hearing the sound what comes on..
Thanks!
Oct 24, 2008 | Televison & Video
Very old Sony Trinitron
Hello gemdsimm,
You right, its cuased by power surge and you should contact nearest Sony service shop for proper repair.
May 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Wire up tv dvd vcr and freeview
hello
connect your sound output from the rear of the TV to your surrond sound system input.
and all should be well.
Thanks Guy9
Mar 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Cambridge Soundworks TVWorks 250 Speaker Logo
85 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
