Question about Orion Xtreme XTR15 Car Speaker
Airspace for xtr series2 15''
Was wondering what would be the best enclosure for 2 xtr series 2 15's.
  • 27 Answers
Well if your talking material i would go with heated plexy glass it has a better feed back
Posted on Feb 06, 2009
Volume recomended for orion xtr series 2 12
http://www.geocities.ws/kewlcat_68/orionpdf/xtrsers2sub.pdf#page=1&zoom=auto,0,791
Go here and all the specs are there..:}
Dec 16, 2011 | Orion Car Audio & Video
I have an old lanzar 10 inch subwoofer that is open airs series and need to know the required airspace for best performance
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Feb 11, 2011 | Lanzar MAX12D Car Subwoofer
Can i put 2 10 l7 or 12's on the rear deck on a 95
I wouldn't suggest putting any subwoofers on your rear deck. put them in the trunk. and if you choose to put them in the trunk you can use either 10's or 12's your preference but for the airspace in that car I'd go for 10's in a to spec and properly tuned ported enclosure. Building them yourself always sounds better if you know what you're doing.
May 25, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Want to find out the best type of enclosure for 2 lanzar max pro 124d subwoofers
you best type of enclosure will be a sealed enclosure or you can build it with a partition in the middle seperating the 2 subs and port each side.
heres a link that will give you the specs for your sub
http://www.lanzar.com/manuals/MAXP104D-124D-154D.pdf
Sep 07, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
Subwoofer boxes ''polyfill''
Polyfill is only used when the enclosure is smaller than recommended. Th polyfill makes the woofer think the internal airspace is more than actual. Your always best to build the box to the recommended woofer specifications of the manufacturer.
Apr 26, 2009 | Car Audio & Video
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w subs
the speakers most not go lower than 2ohms.when the amp. is bridge you are connectin 2 channels.your speakers are most important,the impendence of it,in ohms e.g 4ohms or 8ohms.note make shore the amp.can go down to 2ohms when bridge,or connect the speakers in series.if you not shore.
How to buy the best subwoofer
There are several factors to what sounds good in a subwoofer. Your head unit, amp, enclosure size and enclosure type as well as where its placed. I tend to think that fosgates are superior to a lot of speakers but orion and JL are making some pretty impressive speakers too. Check the speakers need for airspace and make sure you can accomodate it. If you can, and the resonant frequency is more to your liking then move up to fosgates. Personally, I think the difference MIGHT be minimal assuming you are using the same inclosure, amp and head unit. Good Luck!
Dec 27, 2008 | Rockford Fosgate Pl1 210 Stage 1 Dual 10"...
Best sub For RF T10001
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Dec 13, 2008 | Rockford Fosgate T10001 bd Car Audio...
Subwoofers
» sealed box volume: 0.7-1.80 cubic feet » ported box volume: 1.79 cubic feet Hope this helps:)
Sep 02, 2007 | Orion Xtreme XTR12 Car Speaker
Orion Xtreme XTR15 Car Speaker Logo
94 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
